88 650sx only wants to go after a jump/get air - Page 2
Results 11 to 20 of 23
    Sin City USA
    Re: 88 650sx only wants to go after a jump/get air
    32 is pretty high, probably too high. Try something around 20. Most carb issues after rebuild are from using wrong spring or incorrect assembly or cheap a/m kits.
    Aug 2008
    mpls mn
    i ran the ski without the hood, wanted to make sure it wasent getting choked out some how, and you can tell if you give it throttle after idle for a min or parking it goes, then starts to stumble shortly after gets going planes out or almost does, got to be a fuel issue? like when it gets a chance to build up pressure it has enough fuel to go then craps out .
    it did this after i put a spring in and had it at 19-20psi pop off too so i dont know. i hate to spend $50 on a genuine keinin or whatever rebuild kit if it doesnt run better, already spent 30-40 on the rebuild kit , half way to the price of a muikini
    PWCToday Regular Camaro70's Avatar
    Jul 2020
    Long Island N.Y.
    Aftermarket rebuild kits not a big fan of.There are a few decent ones but oem Mikuni or Keihin is the way to go for not much more in price.
    Carbs are funny run great in the driveway warning up and then you put it in water different results.
    Just installed a brand new Mikuni sbn 44 with primer kit and still had to increase the jet and tone down the idle a bit.
    There will always be dialing in depending on conditions type of gas and location you ride above sea level
    Sin City USA
    Good luck
    May 2005
    Right here
    Get a genuine Mikuni rebuild kit. Is $45 not worth messing with it for the rest of the season and losing a ton of ride time? Cripes that's one half the cost of a decent meal at a real restaurant, a full meal at a crappy restaurant, or 45 meals at taco Bell. Priorities son!!
    Changes aren't permanent, but change is.
    Idaho/California
    Get rid of that 28 mm Kehin
    Resident Guru RenoJetTech's Avatar
    Apr 2009
    Reno,Nv.
    Quote Originally Posted by 7808 View Post
    i used the spring in the kit.
    i got the ski with a spring that had almost no hold back pressure, 1-2psi. i replaced it with a spring from the hard ware store cut down then it was at 19 pop off. rebuilt using spring in kit now pop off is around 32
    "spring from the hardware store" wat ? OK keep it low low 30's for now, stock intake.
    Do/Did you have a OEM Keihin Diaphragm in carb to begin with ? I ask so you can compare OEM to this/that aftermarket kit Diaphragm. You've been in this carb with this aftermarket kit a few times I think. To you, do you think this diaphragm appears wet on the plate side ? Your almost there, with what you have, sounds good to rebuild little remote fuel pump, but yeah if it pumps it's pumping. So, diaphragm, pop off, arm level, fuel screw settings.
    '88 550-ride plate,intake grate,intake manfold,carb
    '96 GTX-1mm overbore,F/a's,intake grate,port timed for mid and top end
    '95 FX 1- usually take this motor to 753cc with exhaust porting and reeds
    Aug 2008
    mpls mn
    yeah i found a spring roughly the diameter and cut it down in length until it was around 20psi pop off consistantly (thought that was the target pressure)
    honestly it doesnt seem to matter what pop off pressure or high/low screw adjustments are made, it kind of just runs the same. some times it gets up and goes most the time it doesnt i cant find anything besides the getting the pump out of water always seems to make it rip thing .
    dont want to waste more money on this carb rebuild kits are $50-60 if its going to do the same thing and people tell me "ditch the 28mm carb" so i guess ill try to find a new carb setup
    Jul 2020
    CT
    I'm telling you (with no true knowledge other than personal anecdote) it ain't the carb ...
    Aug 2008
    mpls mn
    so the seals leak at higher rpms and engine load? ill try to pressure test it again, last time my crap block off plates failed and were leaking
