2 Piece Oil Tank Replacement
Results 1 to 6 of 6
    PWCToday Guru millz90's Avatar
    North Carolina
    Hey guys....I am going to replace the famous leaking 2 piece oil tanks on two of my skis, a 2000 GTX Millennium Edition and a 2001 GTX. I have a few questions before i purchase the tanks and was hoping you could help.
    1. Are the tanks the same for both the 2000 and the 2001? I can find one that says its for the 2001 year but nothing comes up when i look for a 2000, but i assume they are the exact same from looking at them. The one i was looking to buy was in the link below.....do you think this would work for both years and is this a good one?
    https://www.ebay.com/itm/Seadoo-OEM-...kAAOSw5FBc6x9a
    2. Are there any grommets or gaskets i need to buy to put on the new tank? Im wondering if here is anything i need to put on at the bottom of the new tank or does the dispensing piece just pull out of the old tank and go into the new tank? Will i need to buy any clips for the hoses?
    Thanks for your help in advance!
    Mar 2008
    so cal
    Re: 2 Piece Oil Tank Replacement
    You can buy a new 2 peice oil tank, but I believe it will also eventually leak at seam. Someone correct me if I'm wrong.
    jacksonville, fl
    weld the old tank,video of fix on this site. and i have done it
    North Carolina
    Thanks guys.
    Bought a plastic welder from Harbor Freight for $16 and welded around the seam. Taped off the bottom hole, filled with water and I still had a couple leaks. I marked them, went back and welded those spots again, filled with water and no leaks! Saved me $100 and the same type of tank leaking again in a year.
    Easy to do as well.
    North Carolina
    I wish i could find a black lid now lol
    Tanks are all the same. I would replace the rubber grommet on the bottom & the one on the top to do it right.
    New ones dont usually leak for a few years. Or say f uck it & go premix.
