How to keep reverse down on 2020 Waverunner EXR when engine is off
Results 1 to 6 of 6
    Apr 2020
    PA
    Trying to get to the rooster tail tubing so I can install an inline shutoff. If the reverse cage was down I could get to it. Can't figure out how keep it down or disconnect it temporarily.
    Any ideas?
    Oct 2013
    funky town
    Re: How to keep reverse down on 2020 Waverunner EXR when engine is off
    Um, take the bucket off......................
    I'm only here to make you mad
    Apr 2020
    PA
    Thanks Captain Obvious.
    Maybe you could explain how you take it off?
    Mar 2007
    Is Everything!
    That ski has the dual trigger RIDE system? Has to be a way to override it. Does it only work with the engine running and retracts when the engine is killed?
    PWCToday Regular ZacFlyer's Avatar
    Alabama
    Correct. You would think it would stay lowered when shutoff to protect the nozzle.
    80 SurfJet 9ft White Build Here: http://www.pwctoday.com/showthread.php?t=492092&p=4550438#post4550438
    82 JS440 / 550 Swap Build Here:
    http://www.pwctoday.com/showthread.php?t=491239&p=4543624#post4543624
    '92 750sx Barn Find Build Here:
    http://www.pwctoday.com/showthread.php?t=493981&p=4561610#post4561610
    '95 Yamaha Wave Raider 700
    '97 Yamaha SuperJet Build Here: http://www.pwctoday.com/showthread.php?t=494510&p=4564967#post4564967
    '16 Yamaha VXR
    Apr 2020
    PA
    Found out how to remove the bucket.
    https://youtu.be/piGuV5tIjWg
