Advant ignition
Results 1 to 8 of 8
Thread: Advant ignition
    PWCToday Newbie Notorious397's Avatar
    Monroe WA
    2
    Advant ignition
    doing a 750 x2 swap and hearing about this advant system. Is it actually worth it and who is selling this set up? Can't find much on it with simple searches
    Oct 2006
    under a ton of work
    Re: Advant ignition
    advent ignition.
    good systems but you need to make sure your electrical system is up to snuff.
    still available new and used come up here and there.
    SE MI
    Re: Advant ignition
    Love the two that I have, they work awesome and really make the skis rip!
    Sin City USA
    Re: Advant ignition
    Advents are really nice because there must be at least 100 curves available, you can get one for virtually any motor setup.
    Apr 2006
    Oregon
    Re: Advant ignition
    Most people are now going Zeeltronic ignitions. Last I heard, Advent is still supporting their products, but is no longer selling them.
    Easy enough to call Advent and find out for sure what the deal is: http://www.adventignitions.com/contact.htm
    Home of Newmiller Machine
    Jun 2011
    Norcal
    Re: Advant ignition
    Is zeel capable of being a charging setup now? Or are they all total loss?
    The one i installed in my freestyle ski is total loss
    - John Kenneth Galbraith
    Best x2 so far- 91 x2, 750 small pin 750, lightened stock flywheel. Msd enchancer, Coffman pipe, 8/16 c75 prop, tbm stuffer pjs RIP turn nozzle, 7400 rpms. GPS 54 MPH
    charlotte,nc
    Re: Advant ignition
    the zeel definitely works with the charging system. just dont remove the magnets in the flywheel and youll have charging.
    96 superjet- rockered, -4, wide tray, adjustable footholds, kv148 mag setback pump, skat 7/14 impeller, rrp adjustable pole, blowsion ovp steering, 62t/62t, ada head, zeel A02T cdi, dual 44s, boysen power reeds, TNT SS chamber
    93-x2, newmiller ported SP750, milled head, R&D single 46 intake, sbn46, fpp blaster chamber pipe, hooker 9/15, umi, rhaas squirrel cage, dakine foot straps
    Monroe WA
    2
    Re: Advant ignition
    Sweet thanks for the information appreciated it!
