I am now on my second rebuild for BOTH of my 03 Waverunners in 16hrs run time. Each ski broke brand new SBT power valves. What am I doing wrong?
03 xlt 800 keeps breaking new power valves PLEASE HELP!
Collapse
X
Re: 03 xlt 800 keeps breaking new power valves PLEASE HELP!
Buying power valves from SBT......http://www.facebook.com/twinlakesjetskirepair
Power Valves need to be trimmed according to the Piston size. For each Piston size increase, the Power Valves Blades need to be trimmed. Or else the Blade will impact the Piston Tops.
Also, if the Power Valve Housing guides are worn out and allow the Power Valves to flutter or 'Butterfly", they will break pretty fast. The Power Valve Slots wear out because, when Power Valves are not cleaned every season, the hardened Carbon buildup wears the slot bigger like sandpaper. You might need more than just new Power Valve Blades.
Comment
Originally posted by JC-SuperJet View PostPower Valves need to be trimmed according to the Piston size. For each Piston size increase, the Power Valves Blades need to be trimmed. Or else the Blade will impact the Piston Tops.
Comment
Originally posted by JC-SuperJet View PostAre you sure? Did you measure both SBT Bores to confirm?
They've been known to only replace one Sleeve, if the other Sleeve is still usable!'05 Honda Aquatrax Turbo F-12X!
'96 Yamaha Super Jet!! 701cc
-Alum Pole. MSD. Factory B-Pipe.
Girlded Head. Worx SS pump shoe. SS Impeller. Scoop Intake. RidePlate. UMI Bars/Grips.
'92 SN SJ Project--- '03 GP800R -For Sale. Great Condition. LI, NY. PM Me if interested!
Comment
Comment
