A Minty Stock 1990 SJ... Whats next?
Results 1 to 10 of 19
    Top Dog jobrown's Avatar
    May 2009
    Little Rock, AR
    Well this is my first time posting in the Yamaha section... I feel a bit dirty doing it, but I have a few questions about my new, most exciting find Ive ever run across. Not really a barn find, but its a yard find. This 1990 SJ has been under a tarp since 2003, just picked it up last night and I'm looking for some insights. Right now it needs a good deep cleaning in some of the harder to reach areas, and probably a carb rebuild.
    I'm going to do a compression test tonight, what numbers should be looking for? I'm currently airing out my garage, pulled the fuel tank and my lord the smell of that gas. Wow.
    Looks like a stock impeller is on there now, I figure that will be the only thing I change on the ski, any recc's for a good all around stock ski with a 200# idiot riding it?
    Other fun things I have found: The spark plugs are original, with the motor paint still on them. Has the original tool kit with extra spark plugs and all. Insane. I'm over the moon with it!
    Oct 2013
    funky town
    Re: A Minty Stock 1990 SJ... Whats next?
    Fuk that thing. Buy a 650sx!!!!!
    I'm only here to make you mad
    Post falls Idaho
    Solas I prop fix it all , is the tray bubbled ? Original impellor is a 4 blade aluminum .
    May 2009
    Little Rock, AR
    The turf is in great shape for the age.. what do you mean bubbled?89DBDDF6-6648-402E-AFBF-389134FAB8A6.jpeg
    May 2009
    Little Rock, AR
    Well it’s not 4 blades... please excuse the dirt dobber nest, I clearly didn’t get under it enough with the pressure washer...3EF066E9-B63B-43C8-ACE0-31572A8AB068.jpeg
    Post falls Idaho
    The early superjets usually have a swollen tray, a lump where you stand , not completely flat , that was remedied in 94-95 , flat trays , almost no pearling at low speeds , early hulls pearl , just ride it and get accustomed to it , it's normal , rebuild carb , add battery and get wet
    Get it running, and ride it...
    Set it for YOU. The mods list for a SJ is endless. If you ask people what to do to it, all you will get is 10,000 different answers, and opinions. Racers, surf riders, rec riders, freestylers all will have different opinions.
    A good impeller is always a good start. Handle bars, and pole spring are other simple upgrades.
    Again, it is a Super Jet. The list is almost endless.... RIDE IT, Decide on what goals you have, and how you want the ski to perform, and go from there.
    email watcon@watcon.com
    Please visit our web site
    May 2004
    LHC
    Solas S is a better choice for a 650 SJ.
    I dream skis E350's Avatar
    Jul 2015
    Sacramento Delta, CA
    Buy a Heavy Duty pole spring from Watcon (i.e., lightened pole handle).
    Learning Slowly...
    May 2009
    Little Rock, AR
    I think more than anything I want to keep it as stock as possible, I could be wrong, but Ive never come across a superjet this clean, this stock, with this few of hours... at least here in arkansas.
    I like the idea of an impeller, bars, lighten the pole with a spring... Keep it as stock as possible. I got it to pop off last night with a bit of premix in the carb, hummed like a champ, so quiet compared to my x2! Carb kit is in the mail, hunting an impeller now.
