Sxi pro bending plug electrodes
Results 1 to 10 of 11
    Mar 2020
    MA
    Iíve got an sxi pro with a factory pipe I picked up beginning of the year other than the pipe engine seems all stock. Ran fine all year until about 2 weeks ago every couple rides Iíll bend an electrode just on the front cylinder. Seemed to narrow it down last night to only happening when I fall and restart the ski. Used a camera and didnít see an signs of the piston hitting the plug. Any thoughts would be appreciated.
    SE MI
    Re: Sxi pro bending plug electrodes
    Any noise coming from the crank? For the piston to move enough to hit the electrode something would have to be wearing out (like the connecting rod at one end or both.)
    Just my $0.02
    PWCToday Guru kotarbi's Avatar
    Jan 2003
    san antonio tx
    You may be running real lean. I had an issue where I was lean or timing too hot Either way I believe I was gettin the electrode so hot the compression was bending it Sounds weird I know. Check your piston wash to be safe
    07 HydroDoo
    Proforce 2.0
    06, 07 SXR's
    85,87,88 Wetbikeís
    Sep 2014
    Utah
    sounds like connecting bearing is on its way out.
    '88 & '89 650sx
    '91 X2
    '92 750sx
    '98 XL 1200 couch
    '07 Ultra LX-parting out haha
    Mar 2020
    MA
    Quote Originally Posted by kotarbi View Post
    Not looking good for that piston
    Idaho/California
    Combustion chamber temp is way up on that hole , detonation , pinging , is taken over , time to upgrade your cooling system for starters , the front hole runs the hottest on a kawi due to all the coolant can only leave from one outlet , over front hole , then to pipe , riding on mostly hot or warm water lakes ?
    Mar 2020
    MA
    water temp in the lake I ride is right around 80 this time of year
    Idaho/California
    That's what I figured , once you fix the engine , pistons , rings , seals gaskets , then upgrade cooling system from the source , aka pump . You have a pro , so you've got the carb situation solved already , mikunis correct ? You also should have the 1/2 cooling hose through the hull , correct ? So then you have to upgrade all brass from pump to engine , 1/4 pipe 1/2 hose , sea doo fittings , then from the pump to the exhaust manifold is now upgraded with larger cooling lines to deliver 300% more water volume to to engine than stock kawi fittings . Then later move on to to gasket mods and bypass fittings , you will use 1/2 black heater hose for cooling lines , just like sea doos , from the pump to the manifold . Will have to drill and tap pump and manifold to get larger fittings to fit
    Jan 2003
    san antonio tx
    Quote Originally Posted by Mbien34e5 View Post
    Hopefully it didn’t mess up the cylinders yet. I would rebuild the carbs and do a leak down test once you get it back together. I remember now. Mine did something similar when I put too much prop in and was running ignition. Detonation from not getting up out of the timing curve
    07 HydroDoo
    Proforce 2.0
    06, 07 SXR's
    85,87,88 Wetbikeís
    Idaho/California
    Yep , lugging was your other skis problem ,over proped
