98 gts died
Results 1 to 10 of 14
Thread: 98 gts died
    Jul 2019
    Maryland
    98 gts died
    Recently rebuilt card and changed all fuel lines on a 98 GTS I purchased. Had it on the water and was running great for a couple of days. Last day was on water for about an hour when all of a sudden it sputtered once and died. Was able to restart after resetting kill switch for about 30 seconds then it died again. Won't start now. Any ideas on troubleshooting steps to try and narrow it down as I'm brand new to jetski's.
    Top Dog SURFnTURF's Avatar
    Sep 2004
    AUSTRALIA
    Re: 98 gts died
    Sounds like it has scored the bore and lost compression in one cylinder.Need to test compression before anything else.Report back and let us know
    Jul 2019
    Maryland
    Re: 98 gts died
    Thanks ... I'll test and report back next chance I get..
    Jul 2019
    Maryland
    Re: 98 gts died
    Checked compression on both cylinders (140-150) so I think they are both good. Checked spark and it is good. Can get ski to fire but most often will only run for a few seconds. Once in awhile it will run for a period but is real rough and when I give it throttle it bogs down. As mentioned the carb was recently rebuilt and had been running just fine before issue started.
    Re: 98 gts died
    Is there any debris in the fuel filter cup or screen?
    Jul 2019
    Maryland
    Re: 98 gts died
    No.. Just replaced last year when I replaced all fuel lines and rebuilt carb.
    Idaho/California
    Re: 98 gts died
    Check filter in carb to verify clean , new needle and seat ? Oe kit on carb ?
    Jul 2019
    Maryland
    Re: 98 gts died
    I pulled carb back off this last weekend and filter was clean. It is an OEM kit (mikuni) on carb... It appears to be getting plenty of fuel. If I have flame arrestor off when turning over I can see spits of fuel out top.
    Idaho/California
    Re: 98 gts died
    Make sure rotar valve is turning , pull carb and plugs , turn over by hand by turning PTO , should see valve moving thru intake manifold
    Jul 2019
    Maryland
    Re: 98 gts died
    Ok I’ll check that but what would cause that not to turn out of curiousity?
