X4 big bore VE impeller ? turnning 8k
Results 1 to 10 of 19
    PWCToday Regular Daveinpa's Avatar
    Sep 2012
    Pa
    Any of you guys running big bore strokers in a X4. I'm running a VE 970 with a 12 vane D75 140mm pump 16/25 with 82mm exit nozzle and she is
    turning 8032 rpm on flat water.
    Need to repitch the impeller but not sure to what.
    https://www.youtube.com/watch?v=dLzyiQu4p7g
    Sep 2012
    Pa
    Re: X4 big bore VE impeller ? turnning 8k
    PWCToday.com Is My Home Away From Home Matt Braley's Avatar
    Dec 2011
    Niceville, FL
    Mercy
    PWCToday.com Is My Home Away From Home jetskijockey's Avatar
    Dec 2007
    Eau Claire, WI
    Family ski?
    Dec 2011
    Niceville, FL
    Quote Originally Posted by jetskijockey View Post
    Family ski?
    lolololol!
    Seriously though Dave I think you are beyond what I can advise at this point. My SS HX800 turned over 7800 but that's the most I've seen. I like your vid with the GPS. That dial runs up quick when you squeeze it! Awesome
    Wait a minute it is a "family ski" actually. It was his son's ski.
    Sep 2012
    Pa
    Thanks Matt
    Took a while to get this engine dialed in now I need to get a impeller matched to the HP, I talked with Glen at Impros and he thought switching from a 16/23 to 16/25 would do the trick, clearly not.
    Skat has no taller pitch options for the 140mm D75 pump so its a guess and go from here.
    May have to find a 148mm pump, not sure what size impeller options that would give me, for sure another 2,000 out of the wallet.
    Going to test an 80mm exit nozzle this weekend but I don't expect to see more then a 100 rpm drop, maybe 1-2 mph gain but still turning 7900
    She is a trip to ride, the power comes on from the crack of the throttle.
    I wish Justin was around to see this run, It was his dream child, Still kicking myself for selling his Big Red Farthing hull. This engine in that hull would have been insane.
    Sep 2013
    United States
    Jesus Christ
    Frequent Poster scensor's Avatar
    Jun 2013
    Greece
    c75 is 140mm
    D75 is 148mm
    I would go for d75 and 16/23 swirl 84/87 nozzles it will drop down 200 rpms at least while you will gain low mid and ofc 1-2 mph at least
    Sep 2012
    Pa
    Not all Skat D75 pumps were 148mm, I have 3 older Skat Mag pumps, 1 is C75 six vane 140mm 1 D75 6 vane 140mm and 1 D75 12 vane 140mm
    I was running the D75 six vane 16/23 & 83mm nozzle in my x4 920 ski with a top speed of 70.1 and rpm at 7750, last fall I swapped the D75 for the C75 mag and ran a Solas SC SD XII 17.5/ 26.5 82mm
    nozzle and ran 71.5 at the same 7750 rpm
    Before I had the 12 vane pump I used the D75 six vane from the 920 on the 970 and oddly enough it ran slower but turned 7950, This spring was the first run with the 12 vane 16/25 and top speed
    was about the same as the 16/23 and yet the rpm went up not down as you would guess going from a 23 pitch to a 25 pitch
    Friday I tried the 80mm nozzle on the 970 and rpm came down 200 but no gain in speed, 80mm is not the way to go
    As of now I'm going to repitch the 16/25 to 16/26 or 16.5x26.5
    Sep 2013
    United States
    Any update?
