Cavitation Problem 04 gtx 185
Results 1 to 10 of 10
    Resident Guru seadooguy13's Avatar
    Jan 2012
    on the water
    I have a 2004 gtx 185 with a brand new sbt pump wearing and a new impeller and I still have a slight problem with cavitation anyone have any ideas what else to look for. It has 190 hrs and runs perfect
    Jan 2012
    on the water
    Re: Cavitation Problem 04 gtx 185
    126 views and no one has a suggestion on how to get rid of cavitation on a four stroke
    May 2012
    Navarre Florida
    What is the wear ring to impeller gape look like. use feeler gauges and measure it. the plastics rings are horrable. if it new it doesnt mean it good. see it all the time. rob
    Owner Operator of:
    RLS Motorwork's 850-226-2748
    Currently Riding
    2006 Sea Doo RXP 215 minor mods 73.2 MPH GPS
    2004 Sea Doo GTX Limited 185 SC 63 MPH GPS
    2006 Sea Doo GTI SE 130. 56 MPH GPS
    1997 Sea Doo Sportster 717 37 MPH GPS
    Working on
    What ever customers drop off.
    Jan 2012
    on the water
    Itís tight canít see daylight through it. I think Iím gonna change the carbon seal the boot and the impeller
    Make sure all the seams around the pump support to the pump tunnel are sealed up.
    Jan 2012
    on the water
    Iíve checked everything Iíve replaced pump Iíve replaced the wear ring Iíve taken the shaft out and looked at the carbon seal and boot I know the engine is slightly out of Alignment can that cause this? Itís also started overheating recently and I am attributing that to the cavitation. Next step is a new impeller.
    Does this have a plastic vane pump?
    Jan 2012
    on the water
    No a brand new sbt aluminum pump
    I just went through helping a customer chase down cavitation on a twin engine 4tec boat. After new aluminum pumps it got a little better but still was there. He ended up buying 2 new impellers from Impros and the problem went away. Turns out somebody had changed out impellers in the past to who knows what, and they were not correctly pitched fr his application.
    Jan 2012
    on the water
    This is exactly how mine is it got better with the new pump but now itís overheating The exhaust
