First JS440 build! - Page 4
Results 31 to 33 of 33
  1. #31
    Apr 2020
    MI
    Re: First JS440 build!
    Itís a Mercury 240 EFI Sportjet. One of the coolest engines ever IMO. Planes in 3 seconds and sounds awesome. I haven't had any issues with it and itís super easy to maintain. The boat consistently does 45 mph with the whole gang on board.
  2. #32
    Apr 2020
    MI
    Finally getting settled in the new house. Bought a truck project as a daily and had to rebuild the differential and a million other things.
    But now I finally have time to start back on the ski!
    Got the hull set up in the barn and will be sanding the bottom of the hull and sealing the cracks. Then bondoing the rest of the scratches.
    Wish me luck!
  3. #33
    First JS440 build!
    If it comes to it elongate the bolt holes on the carb to fit the manifold you have. Ive done it in a pinch and works fine. Just make sure the intake manifold and carb is the same diameter. If it isnít a Drexel on the intake side and match it up.
