First JS440 build! - Page 3
Results 21 to 30 of 31
    Apr 2020
    MI
    Re: First JS440 build!
    Can't edit any longer.
    I think I figured it out.
    The JS440 gasket kit I had has gaskets for both sides of the carb, and they do fit my carb correctly. Thus the manifold is the problem.
    Gonna order one off eBay and hope for the best. Thankfully I have the manifold space because I am certain I will need it to clear the engine.
    EDIT
    Ordered a manifold with the spacer. Also ordered a funky flame arrestor.
    https://projetsports.com/product/tfs...i-standard-kit
    I dream skis E350's Avatar
    Jul 2015
    Sacramento Delta, CA
    There are way more knowledgeable people here than me, so I don't know why they aren't posting. So, I will give it a shot and hopefully they will correct me if I am wrong.
    That is a Mikuni carb you have. (I love Mikuni carbs. The Mikuni SBN44 on our Super Jets and which was added to our X2 650cc are great carbs.)
    But I just checked my wife's JS440 and it has a Keihen carb. I haven't taken apart a Keihen carb and I have heard that they are complicated.
    So, my best guess is that you should be happy that you have a Mikuni, but you will have to buy a different manifold (which you have already determined) to make it fit on the JS440.
    Not really a "snag" but an upgrade opportunity.
    So, carry on. It looks like you are on the right track. And since I will be rebuilding my wife's JS440, we really appreciate all your photos.
    And FYI, my wife's JS440 has the 1980's version of the same flame arrestor you just bought.
    Learning Slowly...
    Apr 2020
    MI
    Thanks E350! I have a 38 mm manifold on the way so hopefully I should be alright.
    I will likely have to fabricate a throttle bracket as I'm missing that as well. But that is easy enough since I have material in the garage already.
    Apr 2020
    MI
    So after lots of cleaning, drying, brake cleaning, vacuuming, etc. I finally got the engine bay clean enough to start spraying.
    Here we have a still wet first coat.
    And just for fun, I thought the sky was pretty tonight.
    and second coat:
    Aug 2019
    NJ
    what type of paint did u spray inside the hull?
    Apr 2020
    MI
    Just some Rustoleum paint and primer in “Thundercloud” gray. I’ve always liked the machine gray look.
    Apr 2020
    MI
    And just for fun, I put a couple coats on the inside of the engine cover as well.
    Aug 2019
    NJ
    any updates?
  9. #29
    Apr 2020
    MI
    Just been working on boring sanding and more sanding. I finally removed all the original safety stickers. About to turn the hull over and glass some small cracks in the bottom.
    I am about to close on my first house and boating every weekend with the family so that has been taking all my time.
  10. #30
    Jul 2015
    Congratulations on your first house!!! It will make you poor in the first few years but rich in the long run!
    Is that a jet pump, I/O or straight shaft boat?
    Learning Slowly...
