VX110 gauge-volts reading all over the place
    Sep 2008
    The flakka capitol of Florida
    Im trying to verify a gauge is working, it lights up when the pink and black wire have hooked up to pos and neg. However, the volt reading will start out around 10, go to 9, then down to 8 something. Then the gauge will shut off and reset. The battery is brand new and I tried using a jump box as well. Same.
    Do I need to put power to another connector/wire, or is the gauge failing?
    Aug 2019
    Gulf Breeze, FL
    Re: VX110 gauge-volts reading all over the place
    This exact thing happened to me in my Seadoo when my fuse plugs were slightly corroded. It was the power wire for my radio and it would fluctuate exactly like yours. Sometimes it was enough to power the radio, other times it wasn't, which made it very difficult to track down. But immediately after cleaning the receptacles out with contact cleaner and putting the fuses in and out a few times to wear the contacts clean the power signal became strong and the issue has not occurred since. That was last season and I have put close to 100 hours on my boat already this season.
    Just re-read your post. Are you saying it happens even when you connect straight to the battery or only when plugged in to the harness?
    Sep 2008
    The gauge isnt connected to the ski, im bench testing it
    Aug 2019
    Gulf Breeze, FL
    Dang, sorry. No help then.
