2019 SXR 1500 dies while riding but is easily restartable - Page 2
Results 11 to 18 of 18
    Resident Guru Dano 7's Avatar
    Nov 2003
    PA
    Re: 2019 SXR 1500 dies while riding but is easily restartable
    Yes I have changed mine. How are you making out? I have a photo on my phone that has a procedure but having trouble uploading.
    Dano7
    04 SXR 800
    17 SXR 1500
    19 SXR 1500
    17 YZ 250X
    Nov 2003
    PA
    https://www.facebook.com/groups/1839051969701763/
    I am trying to get it uploaded....This should have the procedure....If not, Do a search on fuel pumps there....
    Tons of information.....
    Dano 7
    04 SXR 800
    17 SXR 1500
    19 SXR 1500
    17 YZ 250X
    Resident Guru Doug997's Avatar
    Feb 2010
    Las Vegas, NV.
    Finally got it completely installed. I'm wait for the fuel line as one of the red clips fell off. That is due to be here tomorrow. Once I install the fuel line, I then just have to re-install the electronics(bracket w/regulator, sensor and ECU) and I should be good to go
    2017 Kawasaki SXR 1500
    2019 Suzuki DRZ400SM
    2020 Yamaha YZ250
    Nov 2003
    PA
    Good deal! Something just came to mind.... Do you jump wakes a lot? If so, you may want to re enforce the fuel pump/filter with zip ties or sst hose clamps. Excessive jumping will cause the assembly and filter to come apart. I didnít have this happen to me but I did re enforce while I had it apart.....I will try to get a pic uploaded.....
    Dano 7
    04 SXR 800
    17 SXR 1500
    19 SXR 1500
    17 YZ 250X
    Nov 2003
    PA
    Here ya go....
    04 SXR 800
    17 SXR 1500
    19 SXR 1500
    17 YZ 250X
    Nov 2003
    PA
    Or with clamps
    04 SXR 800
    17 SXR 1500
    19 SXR 1500
    17 YZ 250X
    Nov 2003
    PA
    Procedure from FB
    04 SXR 800
    17 SXR 1500
    19 SXR 1500
    17 YZ 250X
    Feb 2010
    Las Vegas, NV.
    No wave jumping. I did install the metal clamps on before re-installing the pump in the fuel tank. Much appreciated on the advise.
    2020 Yamaha YZ250
