Low waterflow through Jetski: Honda Aquatrax
    Jun 2007
    Salt Water
    I am having low water flow issues with my Honda Aquatrax. I am pretty sure it is causing me to overheat when I run at WOT for greater than 15 mins. I dont think my cooling capacity is keeping up with heat generated.
    How can I clean my cooling lines? Would something like "Salt away" work to remove debris and buildup inside my cooling channels?
    2004 Honda Aquatrax R12 - LOVING fuel injection 4 stroke, no more carbs!!
    85' Kawaskai JS550 - PRISTINE condition
    2003 Suzuki GSX-R1000
    96 SeaDoo XP - Sadly missed after my family outgrew its size (2007 -- sold 2013)
    PWCToday Regular guy48065's Avatar
    Feb 2020
    Michigan
    Re: Low waterflow through Jetski: Honda Aquatrax
    I seem to have the opposite problem with my old Kawasaki--puttering around near idle makes the overheat light come on, but I'm fine with normal high speeds.
    I wish I knew how to clean the cooling system but the pitiful service manual only describes the standard after-use flush, and a search here turned up nothing.
    96 & 97 1100Zxi
    Jun 2007
    Salt Water
    I had a corroded water nipple that goes from the engine, with a tube going to the rear of the ski. I replaced it with a new nipple and now I have excellent water flow.
