X2 750 starts wonít stop?
    PWCToday Regular ricketts's Avatar
    Aug 2009
    Fredericton, NewBrunswick
    With the covid shut down I decided to fix my x2 which was in need of love and has sat since the cdi failed 3 years ago. To make things more interesting the starter was seized and it just needed a front to back once over.
    So I ordered up a starter, cdi, and pulled the motor and went through the entire boat. Itís cleaned out and new hoses on the pipe.
    Put it all back together and it starts up perfect but wonít shut off?
    I tested the stop switch no issues? New cdi and I checked the grounds in the e box etc.
    What else could be going on?
    Stopping it by pulling the plug leads isnít that much fun
    Frequent Poster Shawtown_USA's Avatar
    Dec 2017
    Yucca Valley, CA
    Re: X2 750 starts wonít stop?
    Following...
    OE Genuine CDI or aftermarket?
    The machine stops by grounding the CDI with your stop switch. If the switch is good, check the plugs in the harness for corrosion.
    Otherwise bad connection in the box, or bad / faulty CDI
    email watcon@watcon.com
    Please visit our web site
    Aug 2009
    Thanks John it was bad plug in box. Cleaned issue resolved.
