SLow Superjet SN rebuild.
Results 1 to 10 of 19
    I've had this SN for a couple years but I've had other things going on. This one is for the wife. It needed totally disassembled for some nose area repair and paint anyway soooo.......
    Pic is up in the nose area where the waterbox sits.
    Re: SLow Superjet SN rebuild.
    That's fixed from the inside now with glass cloth and epoxy resin. I'll get pics later.
    Was looking at the nose area and thought it would be nice to NOT have a piece of plastic up there to get broken and lost. Couldn't really find any pics like what I was wanting so I just dove in.
    Started with some foam so I could shape it how I wanted.
    I also stuck in some conduit so the pole pivot bolt can still be accessed as I wanted that area closed up some.
    Gas cap will remain out in full view.
    After I closed up shop tonight we ate some grub then went back down to the shop. Got the first layer of glass epoxied in place.
    Wife sat and watched me lay another round of glass tonight.
    Sanded down all the rough and high spots then coated everything with epoxy.
    Flipped it over to grind away all the quickie repairs and start fixing that.
    Got 2 layers of glass cloth on most spots. Found a stress crack at each rear corner too. Went ahead and groung them out a bit and put some cloth on 'em.
    Skimmed over the glass with resin jelly to smooth it.
    Tonight I got the resin jelly smoothed and sprayed on some black guidecoat, then hit it with a block. I'm pretty happy with it. Gonna go ahead and fill in a couple low spots.
    Jumping around a bit........wife picked out some paint at the body supply shop, yay!! Also the engine has been completely torn down and I did some grinding and cleanup today. Mild basic type stuff for some free added power.
