SLow Superjet SN rebuild. - Page 3
Page 3 of 7 FirstFirst 12345 ... LastLast
Results 21 to 30 of 66
    Re: SLow Superjet SN rebuild.
    FINALLY!!!! Bottom wetsanded with soft blocks and ready for sealing with epoxy primer!
    Sep 2019
    Ontario, California
    i almost picked up a beat sn sj.. for a full resto, kinda wish i did now
    Bottom with a coat of 2k epoxy primer. I'm calling it 95%......I'll touch up a couple teeny tiny spots after the topside is done, right before paint.
    Had a bit of time this afternoon. I mixed up some thickened epoxy resin and hit the nose with it.
    The center pic is before..
    Sep 2019
    Ontario, California
    I just picked me up a 90 sj, im missing that front plastic and bumper... i think ill do that same as you. the handle pole is also broken, not sure what route to go with that just yet
    Our handpole also has a crack that needs addressed. No biggie, just epoxy and rivet some aluminum reinforcement inside. Then 'V' grind and build up with glass and epoxy from the outside. Please start a build thread on yours, I'd love to follow along on your progress!
    Sep 2019
    Ontario, California
    could you steer me in the direction of where i can buy some resin and fiberglass? i needs to fix my x2 " previous owner cut out a section of the footwell for the rear exhaust, foamed it, then siliconed and piece back over it" looks crappy, and its not strong at all
    Sep 2019
    Ontario, California
    once i finish my x2, ill jump on the sj
  9. #29
    PWCToday Newbie nc_capozzoli's Avatar
    Jul 2019
    maui of the north
    im digging that nosejob
  10. #30
    May 2005
    Right here
    Quote Originally Posted by CA550sx123 View Post
    http://www.uscomposites.com/
    Changes aren't permanent, but change is.
