SLow Superjet SN rebuild. - Page 2
Results 11 to 18 of 18
    Re: SLow Superjet SN rebuild.
    And then my busy season kicked in full speed!! Starting to cool off now and I can start back in a bit on this. I hit all the engine parts in the blast cabinet just enough to knock off any flaking paint and give the new paint something to stick to. I started assembling the engine today. I got an old school high compression head with badly flaking paint. Blasted off all the loose stuff and coated it with white epoxy. Some new neon pink will be going back on it!
    Engine all together and splattered in '90s fashion.
    Got a bit more done. Did some filling to the driveshaft area.
    Smoothed out a bit. Also sprayed some guidecoat so I can get the bottom ready for paint.
    Bottom skimmed with Evercoat 27. I figured this would be easier than sanding through half the thickness of the hull trying to get the gouges out. Probably have to do this one more time.
    First round complete.......WOW this bottom was rough!
    Second round is curing up right now.
    Can't see much difference except some tan spot putty here and there.
    Sprayed with filler primer and ready for another block sanding.
