Can I use SBT pistons on a nikasil bore?
    Jun 2004
    MI
    I have a 97' Tigershark Daytona 1000 with nikasil bores and was wondering if your pistons and rings are compatible with them? You guys offer steel liners for my ski and didn't know if the ring package that is included with your pistons can only be used with them (steel bores).
    98' Sea Doo SPX Mint
    96' Sea Doo HX Mint
    96' Sea Doo XP - Garage Queen
    95' Sea Doo XP800
    95' Sea Doo XP800 #2 - Was a project, now fully restored and providing lots of smiles.
    97' Tigershark Daytona 1000 - Basket case turned runner
    98' Tigershark TS 1000R - Current project. Needs lots of engine work.
    My Jet Ski videos below.
    Re: Can I use SBT pistons on a nikasil bore?
    The pistons and rings don't care whether they are going in steel sleeves or nikisil.
    Jun 2004
    MI
    That is incorrect. Depending on what the rings are made out of, it does matter. As stated in the article below carbon steel rings with a harder chrome face are not compatible with nikasil bores.
    https://www.jepistons.com/blog/pisto...ials-explained
    96' Sea Doo HX Mint
    95' Sea Doo XP800
    I've yet to ever see chrome faced carbon steel rings in a 2 stroke watercraft engine.......and I think I've had every make and model apart.
    Jun 2004
    MI
    Nikasil plating is expensive and I don't want to risk damaging my new cylinders because I overlooked the rings. Chrome rings are very common in 2 strokes and word on the street is to stay away from them when using a nikasil cylinder.
    96' Sea Doo HX Mint
    95' Sea Doo XP800
