2009 fzs sho oil leak
Results 1 to 6 of 6
    Apr 2020
    florida
    Hi all, have a 2009 fzs that is leaking a significant amount of oil out the back. I have checked the oil filter, cooler , breather and for oil inside the engine compartment, however it appears to be clean and dry. The ski runs great and will hit 65mph with no problem, it just dumps about a quart of oil out the back every 1/2hr. any ideas where this leak may be coming from? When I stop I can see the oil on top of the water behind the ski. Is it possible for the rear crank seal to leak thru to jet drive and out the back? any advice appreciated. Thanks
    Apr 2020
    florida
    Re: 2009 fzs sho oil leak
    anyone have any ideas, i took the ski out with a friend today, it runs great hit 68mph no problem, however it used 1 qt of oil in about 30 minutes of runtime, you can see oil slick on water behind ski when stopped.
    Should be no way for oil to get outside the hull, other than the exhaust when it is running. If you had a leak, you would have engine oil all over inside the hull, not outside in the water.
    Guessing you have internal engine issues, bad oil rings, valve seals, etc allowing your engine to burn (a lot of) oil.
    email watcon@watcon.com
    Please visit our web site
    Apr 2020
    florida
    Thanks for the reply, thatís what Iím afraid of, only thing I canít understand is there is no smoke from burning oil, and the fact that it runs perfect. I think Iíll pull the plugs and have a look at them, thanks again for replying.
    PWCToday Newbie DaveHatz's Avatar
    May 2008
    Gulf Shores, AL
    cdsn99....did you ever find an answer as to why your fzs was losing oil? I started having the same exact problem over the past couple of weeks.
    Apr 2020
    florida
    Quote Originally Posted by DaveHatz View Post
    Yes, it turned out to be a pinhole leak in the oil cooler, a local radiator shop was able to repair it and saved me having to spend over 600 for a new one
