SN confinement Build
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
    PWCToday Newbie 200%absolut's Avatar
    Aug 2008
    Corse du Sud
    Hi,
    Been here for a while but i rarely post ...
    So i think this is a good time to share this build
    Short story :
    I've a Fx1 for a decade, tested a lot of pump configuration on it ...
    It's was sitting for 6 years on the garage and i ride it the last week end before confinement here.
    Years ago a friend gave me an old SN hull, it was laying on my yard since...
    I really like slalom and buoy course.
    The way my modified FX1 handle is good but i want to have a more stable hull.
    Let's go
    Xmetal pole ,Wide Tray, Partial defoam, Midshaft support swap to RN, refoam...
    Aug 2008
    Corse du Sud
    Re: SN confinement Build
    Iv'e found a old Parcel in my garage ...
    Picture one is just after gluing the sponsons with some epoxy
    Picture 2 after sanding and another pass of epoxy and sanding ...
    i've use polyurethane on the back where there is foam and a thick epoxy mix to glue them and make a nice shape with the hull.
    Hard to see but after a little check i didn't like the shape of the transition between the right sponson and the hull.
    after truing both side i manage to have the correct shape with some epoxy mix and a lot of sanding.
    Aug 2008
    Corse du Sud
    I m thinking about have the chines higher, to have a 2008 riding style. Any input about how much to add ?
    Envoyé de mon SM-A505FN en utilisant Tapatalk
    Chicago / Portage, MI
    Saw your other thread with the reply from Mtrhead. If your goal is to get closer to the 08+ SJ hull mods / handling, the rear of the ski was also narrowed. I believe this makes the ski roll easier.
    Mods as I'm aware:
    Tubbies
    Pump and ride plate set back ~2"
    Rear of hull narrowed
    2009 1100 SJ:
    Kawi 1100 build in progress
    2009 SJ MINT:
    1987 WJ650:
    1995 SJ MINT:
    Worx 205 intake [42.5mph gps]
    Aug 2008
    Corse du Sud
    Thanks for you input ,
    Tubbies are on
    I ve add inserts on the hull to setback the pump 3" using another wear ring and a B1 shaft.
    I will make the chines deeper.
    Aug 2008
    Corse du Sud
    Work on progress
    Hull sanding and new chines...
    Aug 2008
    Corse du Sud
    Hi,
    Does anyone have some informations about how handle this kind of hull ?
    I mean with a v on the front versus the flat of a standart SJ
    Pics of rob Flores FR2 hull
    Aug 2008
    Corse du Sud
    Chines are done
    Aug 2008
    Corse du Sud
    Out of my ghetto mold...
    It came out good. Some void to fill but the method i've used to glue the chines does that.
    For those of you interested by the process.
    2 chines homemade in epoxy and glass
    Glue with some fast glue just to adjust them with the original chines.
    Very light epoxy fill to make a first bond
    Some Heavy stuff (epoxy + cut glass) a coat of epoxy fill without glass , 2 thin fiber glass cloth all on one opération.
    Aug 2008
    Corse du Sud
    The tray with primer
    More hull truing almost ready for primer.
