SN confinement Build - Page 3
Results 21 to 30 of 32
    PWCToday Newbie 200%absolut's Avatar
    Aug 2008
    Corse du Sud
    Re: SN confinement Build
    Yes x-metal rn pole
    Envoyé de mon SM-A505FN en utilisant Tapatalk
    Aug 2008
    Corse du Sud
    Pole and hood hook setup
    Aug 2008
    Corse du Sud
    Pump setup
    Solas mag
    11/17 hooker
    Blaster 1 shaft
    Aug 2008
    Corse du Sud
    Better with a pic
    Aug 2008
    Corse du Sud
    Steering cable
    This way i can use teleflex cable without any mod ,and it fits my setback setup.
    Aug 2008
    Corse du Sud
    Plate and grate
    Blank mount to dent the tnt chamber... now it fits just need to make the bracket if Someone has the template.
    Aug 2008
    Corse du Sud
    It's Alive
    After a rebuild of the starter ...
    I just need to adjust the chamber wich is hitting the hull and finishing the water routing.
    Feb 2013
    NorCal
    Sweet! Chamber shouldn't be hitting the hull. Do you have the mount?
  9. #29
    Aug 2008
    Corse du Sud
    Hi Quinc, yes i have it i just need to adjust it a little .
  10. #30
    Aug 2008
    Corse du Sud
    Ride report.
    First test last sunday.
    The balance off the hull is good. It s carving really nice .the wide tray with corner is just perfect.
    The hull is almost dialed. I ve just change the nozzle angle not to sub after a hard turn with a full tank.
    The stock hood is clearly my next mod.
    I need to find what wrong with my carbs...
    As Someone already tested dual am 44's with dual pulse with stock return circuit ? 780cc cylinders
