SN confinement Build - Page 2
Results 11 to 20 of 32
    Re: SN confinement Build
    very nice tray widening. Did you make molds or just very meticulous hand glass work?
    1994 1100 SJ - Dead
    1996 spec hx
    PWCToday Newbie 200%absolut's Avatar
    Aug 2008
    Corse du Sud
    I've cut the tray , shape the foam from the side, then epoxy mix back the side after a cut and a layer of fiberglass to reinforce.
    The floor as 2 or 3 layer where i cut, but just because i was missing some foam . And i ve used a fiberglass cloth wich ended not watertight...
    This is a buoy oriented build that's why i've skip any reinforcement step..
    You can make a nice tray only with fiberglass ,the key is foam shaping
    Envoyé de mon SM-A505FN en utilisant Tapatalk
    Aug 2008
    Corse du Sud
    Tray is painted
    Final sanding of the hull
    Setback pump test mount
    Primer on the hull
    Next is 2 coat of paint for the hull
    Feb 2013
    NorCal
    Looking good!
    Michigan
    Nice work! The SN's are great skis with nearly endless upgrade options.
    Aug 2008
    Corse du Sud
    Painted
    Top Dog RIDEH2O's Avatar
    Jun 2011
    nevada
    Supposed to be 2 thumbs up ^^^
    Anyways, looks good!
    2017 Jet Jam Racing "Region 2" Sport GP Champion
    Thank you sponsors....
    Reno KTM
    DirtTricks
    Reno / Tahoe Watercraft Connection
    Hunt & Sons / VP Racing Fuels
    Garate Enterprises (The Powder Man)
    On the Mark Construction, Reno NV
    Aug 2008
    Corse du Sud
    Turf time...
    Aug 2008
    Corse du Sud
    Done
    round nose pole?
    1994 1100 SJ - Dead
    1996 spec hx
