1986 Kawi js300 help newbie
Results 1 to 10 of 10
    Mar 2020
    Salt Lake City and Green Bay
    Hey all Iím 21 years old and familiar with four stroke motorcycle engines and Chevy small blocks but have never owned a two stroke before. Just got this project js300 and have never owned a boat or pwc before myself (dad has own many inboard boats). Anyways the guy I got it from says it just needs a battery and a carb clean and from my experience itís usually that and then some more. What should I look at before trying to test it out? Also Iím a beginner with two stokes so any help on those would be appreciated like oil gas type? Any help would be appreciated thank you.
    Mar 2020
    Re: 1986 Kawi js300 help newbie
    Main questions:
    Can I run it out of water? How should I do do?
    Mar 2020
    Main questions:
    PWCToday.com Is My Home Away From Home PrickofMisery's Avatar
    Is Everything!
    You can but only for a short period, approx 20-45 seconds. Donít let it get too hot.
    typically most members here do do over a toilet.
    Mar 2020
    Hahahaha oops thanks tho for the info!
    Is Everything!
    No worries. Welcome to the forum.
    Austin, Texas, USA
    Any 2 stroke oil that is rated TCW3 is fine. Don't over rev the engine when it is out of the water -- a couple of blips to around 3000 RPM is OK. If it is still equipped with the original oil tank and pump for oil injection be careful because old oil lines break easily and can starve the engine of oil. Most forum members here recommend using premixed oil + gas.
    Riding mostly Lake Austin
    1984 JS440 -- 1989 650sx -- 1991 X2 -- 1992 750sx -- 1995 900zxi (qty 2) -- 1995 X2
    Quote Originally Posted by cujo View Post
    God intended PWC to be two strokes, as well as dirt bikes, snowmobiles, and chain saws....
    Mar 2020
    Thanks! Yeah I read that they were originally set up to mix in operation but I think I’ll just use the normal tank and just pre mix.
    Mar 2020
    Is there anything I have to do if I want to just run premix or do I just leave all the lines to the carb the same? When I removed the carb to clean it I noticed three lines im guessing ones gas ones oil and ones vacuum? Any help is appreciated, I texted for spark and it’s nice and blue! Next up is the fuel delivery system. So any help on how to get premix fuel to the carb is what I need! Thanks!
    Mar 2020
    Well got a ivy bag fuel system and battery tried to start it up and it got some back fire I’m guessing the timing is off? Someone had it modded or thought advancing the timing would make it faster? How do I check and properly time it? Do I remove the entire stator cover (gas tank side)?
