Square nose build - Page 3
Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 57
    Frequent Poster SurfSN's Avatar
    Oregon
    Re: Square nose build
    Coming along nicely. I dig the pole! I know you’ve got the bushings sorted, but also check out RSKI riders in the future, they made me a set of custom pole bushings to fit a RN pole on my SN. Great and cheap alternative to the hazard bracket
    Chicago / Portage, MI
    Keeping that pole pad is definitely cool. Looks like the square is not so square, it has a mohawk!
    Keep up the good work. Interested to see if you've got handling mods coming.
    2009 1100 SJ:
    Kawi 1100 build in progress
    2009 SJ MINT:
    1987 WJ650:
    6M6, JD Intake Grate, 17/20, Coffmans Sizzler [49.1mph gps]
    1995 SJ MINT:
    Worx 205 intake [42.5mph gps]
    I know it's been a busy season but you got any updates? I finally got some time in on our SNSJ and the Tigersaki is running!
    No it keeps getting put behind customer stuff, I am seriously considering not doing anymore customer work after this year and just buying and selling I have about had enough of it.
    LOL! We've been thinking the same thing! I don't know why every customer thinks they are the only one with a broken toy and you should be able to fix it before this weekend because they are camping. I had a guy show up this year on Fathers Day wanting to drop off a ski! Then they want me to meet them after hours or when I'm closed cause that's when it's convenient for THEM. My wife and I have put a stop to that.....work is work and my time is MY TIME.....PERIOD. In the season I'm 4-8 weeks out and we started telling them up front. Also my wife does ALL the phone calls now and that's weeding out the DIY'ers wanting info to fix their own stuff. It doesn't put any money in my pocket to take all this time telling you how to fix your stuff!! So my wife just tells them 'OK, I'll give him the message and maybe if he gets caught up he can call you back.......then I just never call them.
    If you call me after business hours on Sundays or on holidays I do not call you back ever, the amount of intrusion I have allowed into my private life and off time is ridiculous and I just won't do it anymore period. I agree on the phone calls a staggering amount of them just want info that they can easily Google like everyone else does. I feel I have made enough of a contribution of information here that I don't also have to provide it over the phone .
    I make way more money buying and selling used Seadoos , ATVs and motorcycles than I ever did working on them and have to deal with a lot less people, my plan is to do that and limited service work.
    You want you oil changed , no problem, wear rings, starters , carburetors, no problem, heavy diagnostic, complete engine rebuilds take it somewhere else, I pretty much stopped putting in Reman engines years ago and my life has gotten much simpler, I am just going to tell them I am semi retired and work on a part time basis from now on.
    I haven't updated this in a while so here we go. Time to defoam and refoam this b!tch, I bought a bunch of sheets of 1 1/2 thick blue foam from some guys who were tearing down chicken houses, locally most of it was in really nice condition and was used on my house up by the lake but I have plenty of scrap and a sheet of new 3/4 ' foam left over left over to refoam this with.
    I am trying to figure out how I want to terminate the rub rails at the front so I made a mold with duct tape and poured some 8 lb foam, I will have to play around with it and see if I can get a shape that I like then I will glass over it, remove the foam and finish glassing from the underside of the ski. Then I get to start on the other side and do it all again.
  9. #29
    I got a shape I am pretty happy with , now it's time to glass it up
  10. #30
    All glassed up and foam removed, I also mixed up some epoxy and cabosil and a small amount of phenolic microballons filler, this part is really not structural like the rest of the rubrail and I don't want to lay up 20 layers of glass to get the thickness, so basically the cabosil-epoxy-phenolic is the core , then I glass it up from the underside to finish it off.
    It won't be flexible by any means but the cabosil epoxy dries brick hard , the phenolic microballoons will soften it just enough.
