Smokeysevin roll's his own swap adventure (Critical Failure) 1987 JS550 to 750 Build - Page 8
Page 8 of 8 FirstFirst ... 678
Results 71 to 78 of 78
  1. #71
    PWCToday Regular smokeysevin's Avatar
    Mar 2013
    Houston
    Re: Smokeysevin roll's his own swap adventure (Critical Failure) 1987 JS550 to 750 Bu
    Thanks Amigo!
    I am super excited to both have a little mini-me and to be able to ride this pile eventually. It is getting really close.
    Sean
    The older I get, the more I find myself fixing things that I knew I was doing correctly at the time.
    1987 Kawasaki JankyStandup Build
    2004 Kawi-Doo STX-RXT-X Build
    2001 Toyota Tundra Basketcase Build
  2. #72
    Mar 2013
    Houston
    Detailwork Sans Details
    Started prepping for reassembly and added turf on the rails. Learned a lot in the process. I also prepped the inside of the hull for the Interlux Bilge coat and got a layer on.
    I am kind of worried that something is up with it though because it is sticky and tacks up when I tired to wipe the dust off with denatured alcohol. Consider it is specific bilge paint that is supposed to be chemical resistant I am not happy. Hopefully it is just curing slower than advertised and will eventually harden properly because I really don't want to have to scrape the whole thing down with acetone.
    I also started prepping the pole for the larger inlet/cable route and it looks like my kanaflex is a little stiffer than I would like for where it is. I will either pickup something softer or leave it alone, right now I am not 100% sure which.
    I dry installed the 2 cooling lines from the pump area into the hull and flared the ends so they don't slip off. I need to knock the burr off the flares and glue them in but I am going to wait until I install the exhaust before I glue everything in place.
    Waiting on new pole bushings from Watcon and bow eyes and tow loops from Blowsion. Graphics arrived but I am not ready to stick them yet.
    I need to clean up the motor mount hardware and start prepping to rebuild and install the motor. Getting Close I think...
    Sean
    Something looks off...
    Not bad for my first time wrapping turf rails, learned a lot on how to do it better next time.
  3. #73
    Mar 2013
    Houston
    Old minor update. Added tank pads, waterbox beauty rings, waterbox back strap, front fill cover, tank turf, tank straps.
    Sean
  4. #74
    Mar 2013
    Houston
    Sean Scrambles to Satisfy Standup Success (general assembly and progress update)
    Time Spent:
    36 Hours (over a few days.)
    Tools Used:
    90% of my stock
    Tools Properly Put Away:
    54%
    Materials Used:
    Who knows at this point? I have sure as hell stopped keeping track of what it has cost...
    PPE Used:
    Appropriate for Tasks
    Safety Sandalls
    Number of scratches added to fresh paint: 16
    Total swear words directed towards jetpump/shoe: 750,469
    Percentage complete:
    60% (I think I am starting to get over the hump on this, it is getting really close but I know the last 10% takes 90% of the time which is why I plan to sneak up on it by convincing myself I am really only 60% there. Crazy like a fox)
    I have finally started tossing stuff back together, summer is getting long in the tooth and I am sick of this thing being strewn across my garage, not making brapp noises.
    Last week I got the motor torn down. I gave the jugs a quick flogging with a dingleball hone, then thoroughly flushed them in the parts washer. The crank got new seals and new piston pin bearings. The pistons got dunked in the ultrasonic cleaner until they were decarboned and then tossed onto the crank with new rings. The motor got all new gaskets thanks to our friendly neighborhood @JetManiac and I pressure tested until it held as intended (Big Pin 750 Rebuild Quesitons).
    While I was waiting for the threebond to dry on the cases, I rebuilt the pump with a kit I picked up from @brapperdoodle (gracias amigo) and learned how weird the 750 pumps are compared to modern setups. I only had to take the pump apart once to figure out what was wrong so that was nice. The pump got stuffed with a 10/16 Hooker (750 Swap Prop Recommendations)
    I got some shiny new cooling line fittings and placed an order for my "fuel line" to connect the cooling system up but that got held up in USPS limbo. (Cooling Line Recommendations)
    Even though I had already installed glued in, and flared the cooling lines on the inside of the hull, I had done none of those things on the outer section. That made things super fun to cut and flare the lines with the limited space in the tunnel space... I ended up "clearancing" my flaring tool with my angle grinder so now it is a custom tool. Something tells me I won't get my tool deposit back from o'reilly's anymore if I were to try and take it back.
    Installing the jet pump proved to be a massive pain, the gasket on the front of the pump REALLY didn't want to slide nicely into the shoe, I ended up using some RTV to glue the gasket to the pump, then add a slight lead in chamfer to the gasket. I also added a slight lead in to the shoe which was a tricky thing to do since it was already glued to the hull... not too bright of a move on my part. There is almost no room to install the pump hardware once the cooling lines are installed. I found out after installing the pump that I had cut the cooling/bilge lines longer than I should have so fitting that hose is going to be a real pain but it should be possible without pulling the pump. Learn from my mistakes on this one...
    To stay busy, I started working on throwing stuff together again. I got my coil plug leads sleeved and terminated with self-extinguishing wire sleeving from wirecare and new MSD plug ends from Jegs. Hopefully I did the plug leads right, this was my first time doing them but it seemed relatively straightforward.
    That stuff done, I checked over the motor and found out I had the wrong starter bendix (I had swapped it with a kawi 4 stroke one which spins the opposite direction) installed so I got to take the flywheel back off and replace it with the OG that came with the motor. The cold fusion flywheel lock came in handy so I am glad I kept it.
    Crisis averted, I started fitting the controls and upper pole vent/passthrough. The stock tube was drilled out and removed and I had originally planned on using some kanaflex but the specific version that I bought (a year or so ago...) was too stiff and I didn't like how it popped when the pole went from fully down to slightly up. I ran to holmes depot today and picked up some 1-7/8" ridgid shop-vac hose and set to work making that make sense. I ended up chopping the "threaded" section of the coupler off, sanding the OD down to fit inside a 1.5" long section of 2" ID silicone connector then smushing that into the hole I cut in the pole mount. The vacuum hose itself is about 1.5 feet long and is free fitting inside the 2" SCH 40 pvc pipe I replaced the stock tube with. To install the pvc pipe I had to add a clearance recess into the lower section of the pole and "persuade" the tube in. I then took a 2" pvc coupler and coped it at an angle to match the angle of the inner pole structure to give the new tube something I could attach it to the pole with.
    Once I was happy with that, I grabbed one of the many kawi runabout start/stop switches and spliced an extra 1.5 feet of wire in the middle then sleeved it with braided shielding. The kill switch wiring, 750 throttle cable, and steering cable were then run down the tube and the pole was installed along with one of the wax racing pole locks. I have a 2000 seadoo XP choke cable on the way to wrap up the controls side of things.
    Remaining Items:
    cooling line install
    fuel line install
    stinger outlet install
    wiring
    bilge pump
    battery cables
    reinstall vin plate (removed for painting and because it fell off...)
    install other side graphics
    install rego numbers
    throttle/choke cable mounts
    cut/seal exhaust tube
    fab/install opposite side "exhaust" blockoff plate
    Sean
    2" Sch 40 24" long tube
    Tube Clearance and Hose Spec
    Installed Stickout
    Coped Locking/Locating Flange
    Installed Passthrough
    Vacuum Hose "threaded section"
    Hose Clearance and Install
    Pole Lock from Wax Racing
    Bolted in and aligned and sleeved coil installed. I did have to clearance the aluminum bedplate because the stinger coupler for the exhaust is really big.
    Room for activities? Ignore the non-stuck hood seal...
    Purdy.
  5. #75
    Looks great brother! Cant wait for the ride report!
    The 750 fits a lot better in there the my 701! Just using a stock 650sx pipe but it hits the exhaust manifold and the rubber coupler between the pipe and stinger hits the hull, which I’m not worried about.. may go to the stock breadbox. Will have a lot more room!
    Keep up the good work!!!
    Sent from my iPad using Tapatalk on the farm somewhere….
  6. #76
    Mar 2013
    Houston
    Quote Originally Posted by 550headache View Post
    Gracias Amigo!
    My biggest concern is the starter motor positive feed wire contacting the exhaust pipe, the stainless section of the pjs pipe is REALLY close to the terminal so I am probably going to have to shorten the starter stud, add a "performance dent" to the pipe, and run some extra insulation just in case. Fitting the exhaust coupler on this pipe is a real pain but it technically works even if it rubs the hull slightly.
    On the other side of the motor, I had to trim back the carb spacer bracket corners to keep that from rubbing on the exhaust hose. I may end up chopping that back more but it looks mostly okay for now.
    Sean
  7. #77
    Mar 2013
    Houston
    Wiring is done! "Modern kawi spec" with oe on/off switch, all oe style sumitomo sealed connectors, and "open concept" mounting. All the components are potted and fully sealed so should hold up to the hull environment. Fingers crossed, this will hold up as well the 4 strokes do.
    I also fabbed up a throttle and choke cable mount and installed a 98-2000 seadoo xp choke cable to go with the 750 sxi throttle cable. I am currently waiting on the umi throttle cable adapter before I can get that wrapped up.
    Wax racing bilge switch mount with blowsion rotary switch, and rule 500 auto bilge installed to keep the water out.
    Side note: wiring is really hard to take pictures of, especially when it is fully installed...
    Remaining items:
    Seal driveshaft fitting
    Install bilge pump mount on hull
    Trim and glue exhaust tube in place
    Install fuel tank straps
    Install battery straps
    Trim choke cable
    Fab upper choke cable mount
    Install fuel tank and fuel lines
    Install exhaust hose clamps and bead roll tubes
    Weld exhaust stinger for 2" pipe
    Glue exhaust tube in
    Seal sponson mount access hole
    Goal is to be water ready in 2 weeks.
    Sean
  8. #78
    Mar 2013
    Houston
    Soon
    Sean
There are currently 2 users browsing this thread. (0 members and 2 guests)
