throttle fuel pump question on 951 - Page 2
Results 11 to 12 of 12
    PWCToday Guru Mentzel's Avatar
    Oct 2005
    Anchorage, Alaska
    Re: throttle fuel pump question on 951
    What he said.
    I was running the 95 spring & it siezed when I let off the throttle to low speed. Run 80 gram springs with open filters.
    3/4 throttle would be pilot/main if was a jetting issue. You probably sucked water with open filters so it seized. My old stocker turns 7150 all day long at 63 mph (GPS) with airbox in. No real reason to remove it in my opinion. Even just a little water is bad! SEIZE!
    Nope siezed from being lean.
