95 STS 750 starting issue
    Sep 2019
    WV
    im looking at getting an STS the seller sent me this video while trying to start it. what does this sound like?
    he says the starter is turning but im hearing no fire
    Thank you
    Re: 95 STS 750 starting issue
    Sounds like the bendix is not popping out to crank the motor. I'd take off the driveshaft coupler cover and try turning it over by hand. If the motor is not locked up then the front cover will need pulled. Betting you'll find a rusty mess inside.
    Sep 2019
    WV
    is it a big/hard job?
    Jul 2019
    Bristolville oh
    Nope simple just hard to reach to the front of engine
    Quote Originally Posted by theobsession View Post
    It is best to pull the engine to do the replacement. You will need to pull the flywheel with a special tool, and use heat on the flywheel hub. Personally I will not put a torch down into the hull near the tank.
    email watcon@watcon.com
    Please visit our web site
