550sx hydro turf
Results 1 to 10 of 11
    PWCToday Newbie Mwmiller30's Avatar
    Oct 2018
    Michigan
    550sx hydro turf
    Ripped all the stock pads out as Iím getting ready to hydro turf the tray area. My question is should I continue to fill in low spots like I have on the left rear corner to prep for a smooth turf? What have you guys done about low spots on the side of the tray? Going to order the blowsion js550 hydro turf in hopes of minimal cuts 0A1F8037-1DDE-4531-B5B8-15A057E75999.jpeg
    Any ideas or suggestions are appreciated!
    thanks!!
    Oct 2006
    under a ton of work
    Re: 550sx hydro turf
    make sure to order the SX kit as the regular js won't work.
    you can put padding to make it level.
    Oct 2018
    Michigan
    Finished tops.
    Going to use marine grade puddy on the side next week when I have time.
    Iíll make sure to confirm 550sx turf from blowsion!
    Oct 2018
    Michigan
    Side question. Should I do footholds while I’m at it? If so what ones do your suggest? Is turfing a nightmare?
    Dec 2016
    Portland
    What did you use to fill the sides?
    Oct 2018
    Michigan
    I used a 2 part marine grade epoxy on the tops. After I cut screws out and siliconed holes up.
    Oct 2018
    Michigan
    Finally finished. Wasnít too bad to do and way better than those big stock rubber pads. Used padding to fill in the cut outs on the sides of the tray.
    Top Dog Boz Mon's Avatar
    Jun 2005
    Kankakee River
    Are there holes in the tray under the rubber mats? Is this a kit or did you just buy a sheet of turf?
    1994 FX1
    1985 JS550/650 conversion
    2015 Fiat 500 Abarth
    Oct 2018
    Michigan
    I used a kit from blowsion. Still a ton of cutting needed but gave me the approximate size pieces for each spot.
    Jun 2005
    Kankakee River
    Quote Originally Posted by Mwmiller30 View Post
    Cool thanks. I just ordered the kit. Whatís under the rubber when you take it off?
    1994 FX1
