Kawi 140 Pump in FX1 - Which Prop?
    May 2011
    Minnesota
    I've been reading up for the last few hours, but can't find a consistent answer. Which prop is best for a Kawasaki 140 pump in a FX1. I have a basic setup with B Pipe, 185psi, lightened flywheel.
    The three I see recommended are:
    SXR 13/18 cutback 5mm
    C-75 Skat 9/17
    10/16 hooker
    I plan to get a TBM super cone with it.
    Resident Guru VXSXH20's Avatar
    Jul 2006
    Mid-Atlantic
    Re: Kawi 140 Pump in FX1 - Which Prop?
    140 pump w fixed x2 trim, lightened fw , ported cylinder, r&d afterburner, sxr 13/18, blades thinned down by skat trak cutback 5mm, bpipe, Ada head, wet jet intake and 46mm Sbn carb, modded 62t cdi on my fx1. Itís awesome recipe! She rips
    " It Doesn't Matter Who We Are..What Matters Is Our Plan!"
    May 2011
    Minnesota
    Impros recommended to me the 10/16 Hooker, but I see more recommending the 13/18
    If runnng a R&D pump cone, then 9/17. If running stock pump (no R&D), then 13/18.
