Waveblaster Yamaha 1100 Triple Swap Questions - Page 2
Results 11 to 16 of 16
    PWCToday Regular jpswift1's Avatar
    Sep 2019
    Buffalo, NY
    Re: Waveblaster Yamaha 1100 Triple Swap Questions
    Quote Originally Posted by bigbtch View Post
    So you stuck with the stock 1100 carbs?
    Yes, I stuck the stock 38mm carbs and just jetted them up a little. When you go up to the 44mm carbs on the 1200 65U engine, you really start to drink more fuel, and with the small 'Blaster tank, you'll have to be back at shore to refuel more often. I can say, after riding a 'Blaster with a stock 1200 engine swapped in it, my 1100 with 82.50mm pistons, ported cylinders, and milled stock head for 150 PSI (running on 93 octane pump gas), the 1100 was a little quicker and pulled harder from a stand still compared to the 1200.
    PWCToday Newbie AndyScarth's Avatar
    Dec 2020
    OH
    I have just started my conversion, this past weekend i picked up the ski, 1993 Waveblaster 1. I have the 1996 Wave Venture 1100 im rebuilding. Is this pretty much the same engine as what you have?
    Sep 2019
    Buffalo, NY
    Quote Originally Posted by AndyScarth View Post
    Yes, pretty close. My donor couch ski was a 1995 Wave Raider 1100.
    Dec 2020
    OH
    Ok cool, if you dont mind, I might message you with some questions throughout my build since this is my first. Did you have to do any glass work at all?
    Sep 2019
    Buffalo, NY
    Please do. There's no glasswork that needed to be done whatsoever. It's actually not a terribly difficult swap to complete. The only difficult parts were measuring, measuring, and more measuring to make sure everything went together correctly an also removing the foam from the rear of the 'Blaster. Other than than it wasn't too bad.
    Dec 2020
    OH
    In my case i have alot of glasswork to do lol. Did you remove the foam from the front of the ski as well? How much did erickson machine and performance charge for his work? I am also thinking of using him as i watch his videos on youtube alot.
