550/650 rebuild build - Page 3
Results 21 to 30 of 31
    Top Dog Boz Mon's Avatar
    Jun 2005
    Kankakee River
    Re: 550/650 rebuild build
    Got my factory pipe shoehorned into the ski today. I had to heat up my gas tank to dent it a bit and I put some aluminum duct tape on the tank to protect it.
    1994 FX1
    1985 JS550/650 conversion
    2015 Fiat 500 Abarth
    Jun 2005
    Kankakee River
    Did a test ride on Sunday and had some issues. Water was not circulating at all. The screw on the bottom of the headpipe wasnít opening until almost a half a turn out.
    1994 FX1
    charlotte,nc
    10/10 switch the duct tape for some turf. id also close the bottom screw and use the top and middle. dont be afraid to open the screw past 1 turn either. ive got the top screw on my 750x2 opened 1.5 turns and the middle half a turn and it still rips on top. bottom and midrange acceleration really came alive after letting more water in.
    Jun 2005
    Kankakee River
    Iíll look into the tuning more once the weather warms up. What are my options for turfing they tray if I want to get rid of the rubber rails?
    1994 FX1
    Jun 2005
    Kankakee River
    I tested again today. Started it on the trailer in the water and it immediately started pissing so I took it for a rip. That factory pipe really makes that ski come alive coming from the west coast pipe! Iím really excited to rail some turns and chase some boats once the weather gets warm.
    I also ordered a turf kit from Blowsion so Iím gonna work on cleaning up the ski some now that I know it rips.
    1994 FX1
    Jun 2005
    Kankakee River
    Been working on a plan to turf the ski. Pulled off the rubber mats and the bottom pad and got to cleaning. Today I filled the channels on top of the tray rails with some epoxy resin and cloth. Once that dries I can continue. I cut up the old bottom mat to use on the 6 weird cutouts one the side of the tray.
    1994 FX1
    Jun 2005
    Kankakee River
    This weekend was the first full actual shakedown test of the ski. It was loosing its prime and was very hard to start sometimes, and the issue of course pops up 2 hours away from home. I think the issue was a cracked fuel pickup line. I changed it out today so Iíll test that this weekend.
    I was also having a weak pisser stream so I took the pump apart and Iím pretty sure I had the wrong fitting in there. The removed one on the left
    I picked up some hull braces for the ski. Got those almost all mounted. The rear one on the left side is the only one left because thereís a bilge outlet in the way that isnít used. I cut it so the brace fits around it, but I need some caulk.
    Even with the fuel issues, this thing ripped this weekend for 3 days in a row. Got some good pics of me flying through the air. Once the lake was less busy, I railed some turns and this thing is really fun for that. I built it to be more of a handling ski than a jumping ski but I think itís gonna be pretty gnarly all around.
    1994 FX1
    Apr 2020
    MI
    Those photos are epic!
  9. #29
    Jun 2005
    Kankakee River
    Quote Originally Posted by tacopwr View Post
    Haha thanks! I have some video too which is much cooler but Iím not sure how to post it
    1994 FX1
  10. #30
    Aug 2019
    NJ
    do you have any pics of how you installed the hull braces? I have the nose brace on my 550sx but not the sides. of course iv been a little scared to rebuild the engine, only because I have never done it before and don't wanna destroy a brand new crank so I haven't gotten to ride it yet, been ripping my GPR all summer
