750SXI Pro Pop-off question
Results 1 to 10 of 13
    PWCToday Newbie Corndog69's Avatar
    Feb 2017
    Caledonia
    I know this has been debated several times - but here goes anyway. Need everyones thoughts about my 1998 SXI Pro pop-off settings.
    Ski currently has:
    * Stock size pistons (new)
    * Factory Limited Wet Pipe
    * K&N Carbs
    * ADA head (compression around 170)
    * Lightened flywheel (newmiller)
    * Stock Jets - 147.5 (high speed) and 75 (low speed)
    * Stock needle & seat 1.5
    * stock spring
    * New rebuild on carbs - both set at 30psi pop off
    Factory Pipe says that #80 jet might be a better pilot jet. I would like everyones thoughts about using a 2.0 needle and seat and keeping the jets stock? The reason I'm asking is because I cooked one of the cylinders of my 1 year rebuild and blew out a quarter size piece of the top (outside edge) of the piston. The first cylinder in line looks/is perfect but the second one (front cylinder) is the one that got hot. Exact same carb settings on both carbs - who woulda' guessed......
    The motor is back at Flannery Motorsports to get rebuilt, and I rebuilt the carbs last night. I'm second guessing myself now about pop-off pressure, springs, Needle/seat, and jet sizes. please provide your thoughts as need to get it 100% correct this time.
    Thank you.
    Apr 2006
    Oregon
    Re: 750SXI Pro Pop-off question
    Not sure with K&N flame arrestors, but with PROK or Tau-Ceti I would start with:
    152.5 main jets
    80 pilot jets
    2.0 N/S
    80g springs
    Home of Newmiller Machine
    Green Bay WI
    I have a similar setup, except for SP cylinder and im running the stock flame arrestor with the trumpets removed. I found that stock needle/seat and spring work best. Not sure how much of a difference there is between the two flame arrestors when it comes to intake vacuum.
    -95 750SXI
    -92 750SS
    -81 JS440
    Parts for sale HERE
    Sin City USA
    2.0NS
    80g
    80p
    150-152.5m
    Feb 2017
    Caledonia
    Thanks. What is a good pop off pressure to achieve for strong take offs? I like wave jumping on the lake more than WOT all the time (I’m old ).
    Feb 2017
    Caledonia
    BEULER.....BEULER....BEULER??? Any thoughts out there
    Feb 2017
    Caledonia
    OK, I installed the recommended parts:
    * 152.55 main jets
    * 80 pilot jet
    * 80 gram spring
    * 2.0 needle / seat
    A lot of surveying said this was the best combination for my setup. Wondering if anyone knows a safe starting point for low and high speed screws? Is the second carb usually opened up more than the first one with the pump? I had them set identical the first time and dried up the front cylinder.... thanks.
    Apr 2006
    Oregon
    Set both needles at 1.5 turns out. This should put you in the safety zone and it will probably be a little rich so plan on adjusting the needles to fine tune. Once you get to your ride spot simply follow the tuning instructions as outlined in the Mikuni SBN Owners Manual.
    https://www.mikuni.com/pdf/sbn_manual.pdf
    Feb 2017
    Caledonia
    The carbs are back together and both are at 13psi pop-off pressure. Seems low to me - will that make for good take-offs and wave jumping?
    Sin City USA
    The number is not important. It is the throttle response produced that matters
