Hydro 1100 - Page 8
Page 8 of 8 FirstFirst ... 678
Results 71 to 78 of 78
Thread: Hydro 1100
  1. #71
    Resident Guru RenoJetTech's Avatar
    Apr 2009
    Reno,Nv.
    Re: Hydro 1100
    Is that battery any lighter comparably or the same weight ? Thanks for referral !
    '88 550-ride plate,intake grate,intake manfold,carb
    '96 GTX-1mm overbore,F/a's,intake grate,port timed for mid and top end
    '95 FX 1- usually take this motor to 753cc with exhaust porting and reeds
  2. #72
    Re: Hydro 1100
    Quote Originally Posted by RenoJetTech View Post
    Its about 5x5x2.5 inches so its just a small agm. 210 cca, 10ah i think. It spins motors alot faster than the typical walmart batteries.
    1994 1100 SJ - Dead
    1996 spec hx
  3. #73
    Apr 2009
    Reno,Nv.
    Re: Hydro 1100
    I like the way some explain the ride characteristics of the ski, set -up properly ?, like not very chine/y
    Can kinda see it in hull design, then coupled with engineered and tested pumps must be nice new style/feel
    So with mid size motor great all lake or even ocean ski ?
  4. #74
    Re: Hydro 1100
    Xma145 has a kawi 800 in another hydro and he says he likes it.
    The water tubes are known to break, i wouldnt go to salt water with them unless theyve been pressure tested well.
    They are a carbon/glass composite, i think 40 to 60 lbs lighter than sxr?
    1994 1100 SJ - Dead
    1996 spec hx
  5. #75
    Re: Hydro 1100
    Running well, i think ill need a bigger pitch and up both nozzles 2mm.
    Running all stock 1100, stock carbs, reeds, non dry pipe, etc.
    Very happy
    1994 1100 SJ - Dead
    1996 spec hx
  6. #76
    PWCToday Guru veedubs's Avatar
    Jul 2012
    Atlanta Georgia
    Re: Hydro 1100
    Hydrospace with an 1100 is not fun in the ocean. It subs too easily. Now a Hydrospace with an 800 would be good. I rec ride mine as well as race it. Great all around ski. And yes, no chine walk at all. So much more stable than an SXR 800 or 1100.
  7. #77
    Re: Hydro 1100
    Ripped the old stuff out, put down 2 layers of 1708 biaxial in the tray. I couldnt believe how thin the trays are on hydros.
    New 1/4 underpad and molded diamond.
    1994 1100 SJ - Dead
    1996 spec hx
  8. #78
    Mar 2012
    Romania,Constanta city
    Re: Hydro 1100
    i use stock yam 1200 carbs with adapter plate - 1.5 n/s - instead of 1.2 - work perfect
