Hydro 1100 - Page 3
Page 3 of 8 FirstFirst 12345 ... LastLast
Results 21 to 30 of 78
Thread: Hydro 1100
    I dream skis josh977's Avatar
    Feb 2008
    Cincy, OH
    Re: Hydro 1100
    Quote Originally Posted by 88kawi5fiddy View Post
    I can make some M24x2.0 couplers if you need. 800 couplers drilled and tapped.
    I have the drill and tap @ the house, thanks though.
    Sent from my VS988 using Tapatalk
    '04 SXR
    '96 SeaKaw HX
    Re: Hydro 1100
    NO ONE SAID THIS **** AINT FIT.
    Cut out and welded the water jacket solid. Definitely not fun. Used a solid pound of wire. No way in hell I would try to TIG this
    1994 1100 SJ - Dead
    1996 spec hx
    Top Dog JC-SuperJet's Avatar
    Cypress, TX
    Re: Hydro 1100
    I had 1/8 of an inch milled off the 1100 Exhaust Manifold Flange to pull the Chamber away from my SuperJet Hull.
    Added 1/8" thickness worth of washers to each exh manifold bolt to make up for the material removal.
    I think the SuperJet Hull is smaller than the HydroSpace?
    Re: Hydro 1100
    This is about /4 if not more. That's gonna start messing with the pipe tuning... so I just took out the water jacket.
    Ghetto rigged to test it.
    Anyone know why only the middle cyl is firing? All plugs are sparking and I flipped #1 and #3 to no avail.
    1994 1100 SJ - Dead
    1996 spec hx
    Feb 2008
    Cincy, OH
    Re: Hydro 1100
    Mag cylinder is #1 (long wire) , Pto is #3 (shortest wire). The motor will backfire if you swap 1 & 3. Sounds like a 12 GA going off in the garage.
    '04 SXR
    '96 SeaKaw HX
    Re: Hydro 1100
    Hmm, that would be the case, depending on where the last racer mounted it. Guess I'll have to try it the short on front again tomorrow. And get brand new plugs...
    1994 1100 SJ - Dead
    1996 spec hx
    Feb 2008
    Cincy, OH
    Re: Hydro 1100
    I just swapped the internal coil wires when I rewired mine wrong the 1st time. Oopz!
    '04 SXR
    '96 SeaKaw HX
    Chicago / Portage, MI
    Re: Hydro 1100
    Was this a 08+ hull? I am running 1/8"-1/4 milled off the exhaust manifold face and I had Judge cut the side of the pipe flat, weld inner and outer chambers. Fits like a glove now with about clearance of two layers of hydroturf. More than the sxr1100s.
    88kawi did you pressure test the chamber? Judge did it to check the welds as well as fix a bunch of pin holes which were leaking. They were all on the inside bottom, where water sits. This was on a excellent condition chamber with almost no corrosion visible.
    2009 1100 SJ:
    Kawi 1100 build in progress
    2009 SJ MINT:
    1987 WJ650:
    1995 SJ MINT:
    Worx 205 intake [42.5mph gps]
  9. #29
    Cypress, TX
    Re: Hydro 1100
    "Was this a 08+ hull? I am running 1/8"-1/4 milled off the exhaust manifold face and I had Judge cut the side of the pipe flat, weld inner and outer chambers. Fits like a glove now with about clearance of two layers of hydroturf. More than the sxr1100s."
    1/8" off the Exhaust Manifold was just enough to just barely clear the Hull in my 2012 SuperJet...
  10. #30
    Re: Hydro 1100
    Lol ya not see my sh1t weld? If it does leak I'll just buy another one. This chamber was $20 with the hull. I dont even expect it to run all weekend to be honest. I dont even think it will touch water before I leave and take it and the superjet to havasu!
    1994 1100 SJ - Dead
    1996 spec hx
