Hydro 1100 - Page 2
Page 2 of 8 FirstFirst 1234 ... LastLast
Results 11 to 20 of 78
Thread: Hydro 1100
    Re: Hydro 1100
    Quote Originally Posted by rog_i View Post
    Can you not run 44s on there?
    You can, if you spend $850 building your own set, or run gp1200 carbs and figure out jetting.
    I already have carbs, adaptors, flame arrestors, and know close jetting. I also want the fuel tank to last longer. 44's or 42 sudcos before next season maybe.
    1994 1100 SJ - Dead
    1996 spec hx
    Re: Hydro 1100
    1.25" spacer for the kawi 650 motor plate will be perfect. This is 1.5" yeah, its ghetto, but yeah, its also super simple ans stupid. KISS method.
    Pump and impeller and driveshaft and carrier are all installed.
    Doing the 1100 exhaust dry mod. Its pretty easy. I have weld-in bungs with jetworks spray bars.
    Should have tons of room for a medium waterbox that will have either 1 or 2 weld in bungs. One will be a spray bar, the other will be tunable.
    1994 1100 SJ - Dead
    1996 spec hx
    Chicago / Portage, MI
    Re: Hydro 1100
    Cool build, I'm interested to see how this turns out.
    That 1100 pipe looks really crusty. It might be worth pressure testing it to see if you've got any leaks in the water jacket to the outside. On the pipe Judge cut for me, for my 1100 SJ, there was a ton of pin holes. Even one area which was so bad he had to weld a plate over it. And this is from an otherwise mint looking plate. Most of the issues were on the inside bottom, where water would sit in the jacket.
    Keep out the good work. I have always been curious about how good this hull is. We have two limited 1100 sxrs in our group which are good. One Judge ported superstock with mtrhead's hull / mods and it's amazing.
    2009 1100 SJ:
    Kawi 1100 build in progress
    2009 SJ MINT:
    1987 WJ650:
    1995 SJ MINT:
    Worx 205 intake [42.5mph gps]
    PWCToday Guru veedubs's Avatar
    Jul 2012
    Atlanta Georgia
    Re: Hydro 1100
    I used 6061 Aluminum blocks for mine. Kinda copied the “kit” that BNJ made. The idea you are using will work. I used a similar idea on my Hydro 750 build.
    Jul 2012
    Atlanta Georgia
    Re: Hydro 1100
    Here is my 750 setup.
    I dream skis josh977's Avatar
    Feb 2008
    Cincy, OH
    Re: Hydro 1100
    Quote Originally Posted by veedubs View Post
    Is that an ADA coupler?
    Sent from my VS988 using Tapatalk
    '04 SXR
    '96 SeaKaw HX
    Jul 2012
    Atlanta Georgia
    Re: Hydro 1100
    Quote Originally Posted by josh977 View Post
    Yup, I got the last ones they made apparently.
    Re: Hydro 1100
    Oi, i need some water manifolds..... hook a bruddah up?
    How thick are the bars? 1 3/8 or 1.25"
    1994 1100 SJ - Dead
    1996 spec hx
    Jul 2012
    Atlanta Georgia
    Re: Hydro 1100
    Quote Originally Posted by 88kawi5fiddy View Post
    I only have the ones that came with my hulls. I’ll measure the bars tomorrow but I think they are 1.5”.
    Re: Hydro 1100
    I can make some M24x2.0 couplers if you need. 800 couplers drilled and tapped.
    1994 1100 SJ - Dead
    1996 spec hx
