Genesis thrust issue - Help Needed ASAP
    PWCToday Regular jakew4's Avatar
    Jul 2006
    San Diego (America's Finest City)
    To start, I'm a Yamaha guy and have never worked on a Polaris
    IMG_20190810_121508.jpgIMG_20190810_120951.jpgI have my brother's Genesis that has lost thrust. The motor runs great, but it does not propel forward in water. Does anyone see anything wrong with the picture? Should this section of the shaft covers with the rubber hose have the bend to it? Also, the aluminum piece with the zert fitting spins freely by hand. Any help would be appreciated.
    Jake
    Aug 2010
    delavan, wi
    Re: Genesis thrust issue - Help Needed ASAP
    Looks like the coupler failed, bet you can spin the drive shaft around in the pump. Just make sure the battery is off or you could lose some fingers.
    90 Superjet - Coffman pipe, other mods
    98 Polaris Pro 785 - stock graphics, just ported and polished
    98 Polaris Pro 785 - black top, cylinders milled .020, ported, polished, watcon cooling
    95 Kawasaki 750 sxi - R&D pipe, ported, polished, bored 1.5mm over
    01 Polaris 600 sc xp sled - Stock
    Jul 2006
    Awesome. I'll pull the pump and update what I find. Thanks so much!
    Sep 2002
    Upstate NY
    Unless its just the camera angle, things look terribly misaligned. I'd be checking motor mounts and pump alignment for sure.
    FICHT EMM Repairs (Polaris, Kawasaki, Tigershark)
    http://lakesidetech.biz/
    http://fb.me/lakesidetech1
    http://fichtemmrepairs.com
