Never trust the blue marks
Page 1 of 3 123 LastLast
Results 1 to 10 of 26
    Aug 2018
    NC
    As title states. Never trust the blue marks when timing the balance shaft to crank.
    Just finished building a 951 DI. Engine installed aligned, etc, etc. Cranks right up but shakes like a paint mixer. I mean it shakes.
    I remember thinking something was odd when I aligned the blue marks for timing but wrote it off as being a result of the air pump.
    With air pump at TDC the mag piston is no where near TDC. As far as I can tell when mag piston is at TDC so should the air cylinder.. Can anyone confirm?
    Also, I think I have come up with a way to fix the timing without tearing down the entire engine. Again some input would be appreciated.
    Can I put the engine upside down on the bench, and just split the case halves, correct timing and rebolt the case halves together? Am I asking for trouble doing this? If at all possible I'd like to avoid having to buy a new headgasket, possibly new base gasket, reseat the rings, etc, etc, etc.
    Did I mention that you shouldn't trust the blue marks?
    Top Dog Benflynn's Avatar
    Aug 2015
    Birmingham
    Re: Never trust the blue marks
    I would start with why they are wrong, and I see no reason u can’t pull the bottom
    Aug 2018
    NC
    I would start with why they are wrong, and I see no reason u canít pull the bottom
    Motor was just rebuilt and reinstalled. Fresh rebuilt, crank, balance, pistons, sleeves, etc. etc.
    Presumably crank builder pressed gear on wrong. I rebuilt the balance shaft myself, marked everything and did not even remove the gear.
    Scouring the forms yields a few other cases of incorrect marking of gears -- even found a case of it happening to Bill.
    Top Dog SURFnTURF's Avatar
    Sep 2004
    AUSTRALIA
    Turn upside down, Remove lower case, align crank by using case half surfaces and weights for crank and balancer being opposites. Apply Gasket sealer, torque up. Have done it a few times, some my fault, some the machinist.
    Yeah I did one wrong once....ski shook so bad spilled my Mt Dew.
    Aug 2018
    NC
    Quote Originally Posted by SURFnTURF View Post
    Thanks, good to know. engine is pulled and on bench. Might try and power through it today.... I do need to eat at some point though.
    :lmao
    Aug 2018
    NC
    I have the bottom end open and the timing is totally wrong. Blue marks line up as I remember. But something definitely seems off with the balance shaft. I rebuilt the balance shaft myself, but everything I took off was marked, and on reinstall the marks were lined up.
    The balance shaft weights are closer to 90deg off than 180. I thought this had something to do with driving the air compressor piston -- but I question what is correct? The air pump was in rough shape when I rebuilt it. Perhaps it cause the counter weight to rotate? It seems highly unlikely. The air pump rod wasn't bent or anything like that.
    At any rate that's not the only problem. The mag side balance weight is 180 of where it should be, so I may have more than one problem.
    Some pictures to describe what I am seeing:
    Sep 2008
    The flakka capitol of Florida
    definitely off. The counterweights on the crank should be 180 off of the balalnce chaft weights
    Sep 2008
    That shaft isn't usable as is.
    Sep 2008
    A blind person pressed that balance shaft together.
