Another 640 Tigersaki build - Page 2
Page 2 of 7 FirstFirst 1234 ... LastLast
Results 11 to 20 of 67
    I dream skis matt888's Avatar
    Apr 2005
    CENTRAL FL
    Re: Another 640 Tigersaki build
    Subscribed.
    SOLD! HONDA AQUATRAX 2 SEATER
    1987 JS440 SUPERSTOCK
    1988 JS440 FREESTYLE
    1987 JS550 LIMITED
    SOLD AND MISSED VERY MUCH, 1994 WAVEBLASTER LIMITED
    WWW.HONDAOFWINTERHAVEN.COM
    1987 AM. WORLD CUP CHAMP
    My album http://www.pwctoday.com/album.php?albumid=2000
    https://youtu.be/S3KAF71mm4o
    Got the exhaust manifold modded. The Tigershark pipe will flip around forward and bolt right back up!! But in doing so you lose a bolt hole. I don't think it's a big deal cause you still have 4. But, I drilled and tapped the extra hole anyway.
    I got everything up front ready to bolt up as well. Just need to pick up a flywheel key. I also found a dual carb setup with intake........probably stick with the single though.
    PWCToday Newbie Justsendit's Avatar
    Jun 2018
    PA
    Nice! keep it up
    77 JS440 :
    Jetlyne ss 15.5 prop and jetlyne reduction nozzle
    Westcoast pipe and exhaust manifold
    DG quadrafin ride plate
    Supertrapp waterbox
    Lightened flywheel
    Westcoast velocity stack
    Blowsion tubbie 1s
    Rowdy rooster
    87 300sx:
    Skat-trak ss15.5
    Milled head
    Mariner pipe
    38bn carb
    Chicago / Portage, MI
    Interesting. Besides doing this conversion for novelty sake, is there some advantage of this engine over a Kawasaki 750? Just curious, I don't have any experience with these engines. Having one on hand is a good reason to give it a try. Just about every engine and pipe I have, at some point I've thought about stuffing into my Wave Jammer.
    2009 1100 SJ:
    Kawi 1100 build in progress
    2009 SJ MINT:
    1987 WJ650:
    1995 SJ MINT:
    Worx 205 intake [42.5mph gps]
    I guess one advantage would be, no expensive exhaust to buy......or mounts. Another is.....640 Tigersharks seem to be sitting around with good engines and jacked up pumps. That's the one I went with! Horsepower is the same.
    May 2007
    Great creative thinking, should rip for cheap.
    Nice. Interested to hear how this turns out, and what impeller works best.
    2009 1100 SJ:
    2009 SJ MINT:
    1987 WJ650:
    1995 SJ MINT:
    I dream skis jetbum's Avatar
    Oct 2004
    Dirty River Rider Dunnville, Ontario
    Any updates
    Officially done owning skis but I still like reliving the old days
    I know, I know........been too long. Just seem to always have a lot going on. My son bought a '66 Lincoln and we pulled the motor and trans and tore down this winter. And I finished a few more 'other' projects.
    Anyway, had time to do a bit today. Looks like the 640 needs 1/2" of spacing above the 550 mount plate to line up the couplers nice. The dual carbs DO fit right in. And with a bracket of some sort the stock choke cable will work.
