951 thermo sensor switch?
    Apr 2008
    SoCal
    In the manual i see 2 temp switches. One is a Thermo sensor switch, and the other is a water temp sensor? Is the Thermo sensor switch used overheat? If so, what is the Water Temp sensor used for?
    Dec 2006
    Re: 951 thermo sensor switch?
    The Water temp sensor(located next to the jet pump nozzle on the ride plate) measures the temperature of the body of water you are playing in. The Thermo sensor only sends a signal to the MPEM to tell the beeper to sound off alerting you of an engine temp overheat.
    96XP Wake-jumping demon #1
    96XP Wake-jumping demon #2
    Apr 2008
    SoCal
    So neither of these sensors will send it to limp mode? Or is there even a limp mode function on 99+ 951 carb engines?
    Dec 2006
    Quote Originally Posted by Spades View Post
    Limp home mode is not a function on the early 2 stroke carb'd ski's.
    According to the 2002 manual I have pulled up, the RFI models(being injected) have a "Fail-Safe" function and the DI equipped models have a "Limp-Home" mode, respectively.
    Dec 2006
    The schematic you are looking at only applies to the GTX, GSX RFI, and GTX RFI skis equipped with an INFO CENTER gauge.
    Sent from my Pixel 3 XL using Tapatalk
