BJP Prize Ski Build - Holy Grail Squarenose - Jet Blast 2020 Wisconsin Dells Freeride - Page 3
Results 21 to 30 of 47
    Dec 2005
    Wisconsin
    5
    Re: BJP Prize Ski Build - Holy Grail Squarenose - Jet Blast 2020 Wisconsin Dells Free
    Pump is in, OP nozzle is installed, and steering is aligned (water test will confirm when it's not 20 degrees out ).
    The OP nozzle that was donated was used and had the typical pivot hole egging they are known for - especially bad on the bottom. I didn't take pictures of all the details, but I basically installed (epoxied in) new stainless sleeves into the pivot holes of the nozzle and then carefully made fitted bushings top and bottom. No more stainless bushing against the bare cast aluminum nozzle. I've repaired several like this, and they have all held up well.
    WHEN IN DOUBT, GAS IT!
    Dec 2005
    Wisconsin
    5
    Oh yeah, the stainless swirl prop was in this SJ when I bought it. Condition and clearance is all very good, so I didn't mess with it. Not sure what the pitch is, but if spring test rides reveal the pitch isn't appropriate, I will deal with it then.
    Now I just need to decide what I'm doing ride plate and intake grate wise.
    Dec 2005
    Wisconsin
    5
    Little more progress. This SN still had the original plastic OEM intake grate when I bought it. I normally prefer the R&D pro-series intake grate (after trying at least one of everything since the 90s), but I'm not a fan of attaching any kind of really aggressive scoop grate to an old original plastic pump shoe, because you're basically creating a ticking time bomb = that shoe is gonna snap, and you might lose an expensive grate.
    So instead I like to take these old cast aluminum grates from VXR650s and cut out the 2 center bars and blend everything nicely. Then I also make a 2mm thick shim for the rear mounting point. It's a good balance of improved hook up without stressing the pump shoe too much.
    20191221_171046.jpg20191221_171054.jpg20191221_171058.jpg20191221_171105.jpg20191222_152159.jpg20191222_152341.jpg20191222_152235.jpg
    Paul, I have donated these in the past for builds, and would do so again as long as it actually goes on this ski.
    https://www.watcon.com/jet-pump-driv...e-yamaha-sj-b1
    Either come pick it up, send someone, or pay for shipping.
    Zig
    email watcon@watcon.com
    Please visit our web site
    Dec 2005
    Wisconsin
    5
    Ride plate installed. This SN came to me with an OEM plate, but I really wanted at least something a bit longer. Fellow BJP Keith S donated this Tucker Rocky plate at the jet ski rummage sale we held back in October. It's got the rear screw adjusters just like a stock plate. One was stuck, but I freed it with heat and persuasion, then removed and greased both of them in case the new owner wants to drop the rear of the plate. Also note that the mounting holes for the early version offline bilge have been nicely filled in. Don't need them when running the later version reduction nozzle with incorporated bilge.
    20191224_144013.jpg20191224_144023.jpg20191224_144028.jpg20191224_144044.jpg20191224_144640.jpg
    Dec 2005
    Wisconsin
    5
    If anyone is looking for a stock SN ride plate, hit me up, as I will probably sell the stocker from this ski. It was damn near perfect. Great candidate to d-cut.
    Dec 2005
    Wisconsin
    5
    20200215_121527.jpg20200215_121339.jpg20200215_121323.jpg20200215_121356.jpg20200215_121435.jpg20200215_123926.jpg
    I took a break from ski building to build some beastly beach stands out of 3 inch PVC .
    Dec 2005
    Wisconsin
    5
    Just taking a break from huffing PVC primer and glue to huffing heat paint fumes instead. Raffle ski 701 is a healthy 155psi in both holes, but the paint wasn't looking so great, so she got a good clean & scuff, then some fresh heat paint.
  9. #29
    Dec 2005
    Wisconsin
    5
    The motor that came with this 95 SN had a messed up ebox thanks to someone not understanding, well, I don't think they understood anything to do with electricity - too much to explain. It needed a new starter relay, some clean up, and to have the wiring sorted a bit. Got that handled, and ran a simple test on my motor cart. I also installed a healthy OEM starter from my bin of spares.
    https://youtu.be/wDuwbOhutSk
  10. #30
    Dec 2005
    Wisconsin
    5
    Just a bit of timing advance and some progress.
    The big surprise is next...
