650sx - TBM Pump Cone “pro” or swap in a different pump?
Results 1 to 10 of 14
    PWCToday Newbie Jakeevans420's Avatar
    Jun 2017
    Michigan
    3
    So since the price of these pump cones have gone up it has me wondering if there is an alternative that’s better???
    89 650sx - 2mil over mariner pistons, westcoast head 210psi, pipe mod + extended chamber with divided manifold, sudco 42, lightened flywheel, jetlyne scoop grate, ocean pro ride plate, 15.5 impeller, dual cooling....
    PWCToday Guru 92Kawasaki750SS's Avatar
    Jul 2015
    United States
    Re: 650sx - TBM Pump Cone “pro” or swap in a different pump?
    No alternative to a pump stuffer. The TBM or R&D stuffer is your cheapest "mag" pump option.
    Oct 2017
    Wyo
    I really like my r and d stuffer.
    Jun 2017
    Michigan
    3
    What differences did you notice?
    Green Bay WI
    The alternative would be a Skat or Solas pump. It will be better, but will cost many times more than the pump stuffer.
    -95 750SXI
    -92 750SS
    -81 JS440
    Parts for sale HERE
    Oct 2017
    Wyo
    Better hook up and less cavitation. Put it in with other changes but possibly better acceleration and top end.
    Jul 2015
    United States
    I installed mine last, after all kinds of mods on my 650sx. I feel it gave me better acceleration, better hook up, and less cavitation at times.
    Sent from my SM-N920V using Tapatalk
    I dream skis bird's Avatar
    Jul 2012
    La Crosse right on the RIVER
    Quote Originally Posted by 92Kawasaki750SS View Post
    Did you already have a Big hub impeller?
    My SXR had the big hub on it(stock), making it a mixed flow pump. Putting the R&D Stuffer in it last summer made the ski feel much more hooked up. The pump is now matching the speed of the water entering it.
    My correlation has been that a mixed flow pump is like doing a power slid on a sport bike, while axial flow feels like being on rails. Power sliding is fun, but rails hold the edge
    Worth the $300 for sure.
    Third Coast Freeride - Midwest Wave Warriors
    Wooka Wooka Wookay. Let's Fing Rage!
    Jul 2015
    United States
    Yes, I had a C75 big hub swirl 9/17 prior to the R&D pump stuffer. I also added an R&D top loader when I did the pump stuffer, and the ski can carve really well...
    Green Bay WI
    Quote Originally Posted by bird View Post
    How does a big hub impeller turn a axial flow pump into a mixed flow? All you are doing is changing the hub diameter, as long as your outer pump walls are cylindrical, its still axial.
    -95 750SXI
    -92 750SS
    -81 JS440
    Parts for sale HERE
