Fuel Pump Issue FX140
    Feb 2015
    Sarasota
    Hey,
    So I've got a real head scratcher. I recently went to fire up my ski, no start. Long story short found out my fuel pump wasn't turning on with the ski.
    Went through the service manual and checked the relays and everything check out per specs. Checked the fuses, all good. Even swapped relays and ECU with the wife's ski.
    Finally just pulled the pump and hooked it up to a battery, sweet molasses it worked! Check the voltage at the plug/white connector is giving a reading of 5.5-6V.
    I believe the fuel pump requires 12V? AND if I am correct why I am only getting 1/2 the voltage required????....
    PWCToday Newbie Matchsticks's Avatar
    Apr 2019
    SoCal
    Re: Fuel Pump Issue FX140
    Most likely corrosion, if it’s not getting proper voltage then you’re probably putting that power somewhere else. I’d check all wires and connections before chasing more costly solutions
    Ohm out the harness from fuel pump ground to the block or battery. The grounds in the Yamaha harnesses tend to go flaky.
    Feb 2015
    Sarasota
    Update,
    I did some wire tracing and ended up being a bad ground.
    Added a ground from the battery to the pump and ran just fine. Then i repaired the bad ground
