Seadoo Neoprene pump gasket/seal question.
    Sep 2012
    Somerset
    I am rebuilding the pump on my 2011 Seadoo GTI SE 130 and ordered a new pump seal part number 293200087 and received a flat neoprene gasket with adhesive backing on it. To be honest it looks like a real piece of crap and I am contemplating just putting the original molded rubber seal back on instead.. Any comments or advice from anyone that has installed this version of pump seal before.
    Your thoughts please
    Denncro1
    Sep 2008
    The flakka capitol of Florida
    Re: Seadoo Neoprene pump gasket/seal question.
    SBT sends out some sort of foam comprised seal with their 140mm wear rings. I wouldn't use them either.
    Sep 2012
    Somerset
    Thanks KCR357.
    The oem molded rubber seal is all you need.
    Feb 2002
    Vancouver, BC Canada
    Quote Originally Posted by Denncro1 View Post
    Denncro1
    They sent you the wrong one. Google the part number 293200087 images.
    Chester
    Stand up:
    98 SXi-Pro
    Couches:
    96 XP
    86 X2
