gsx rfi starter won't turn engine over
Results 1 to 10 of 10
    Sep 2008
    The flakka capitol of Florida
    Tried 3x starters, oem, new, no difference.
    Tried different batteries, jump box, using a car battery plus the ski battery, nothing.
    Tried bypassing the stock wiring with cables to eliminate possibility of corroded starter/negative battery cables, nothing.
    Engine spins freely, no hangups, starts up fine when I can position the engine at the perfect spot to allow momentum to get it turning over, but any other time it'll spin the engine to tdc then nothing.
    Tried bypassing the solenoid, nothing.
    Next step is setting ski on fire.
    Oct 2013
    Ohio
    Re: gsx rfi starter won't turn engine over
    So, sometimes it starts ok, but other times perhaps most times, it does not start?
    When yu try to start it and nothing happens, do you get any sounds or anything? buzzing, humming, wires heat up? anything at all?
    Sep 2008
    It'll try to turn over every time. If the pto is turned so the piston is midway between top and bottom, it'll get enough momentum to spin. It *will* sometimes, when it does start spinning, quit turning over even if the button is still depressed
    Check your injector spray. Maybe it's hung wide open and almost hydrolocking with fuel????
    Oct 2013
    Ohio
    Try to give us a better idea of what is happening
    Senarios;
    1. Does the starter motor continue to spin and the engine stops? OR
    2. Does the engine jerk to a stop and the starter stalls? OR
    3. Does the engine come to a slow stop, like that starter has stopped trying to turn it? OR
    4. If something else happens, try to explain...
    Possible issue for each senario;
    1 Missing teeth on the flywheel OR a damaged bendix clutch? You mentioned you tried 3 starters, does this model have a separate bendix? or are you using the same bendix with each starter?
    2. Something in the engine forces it to stop.. Perhaps as mentioned above, hydrolock or something?
    3. Some electrical issue not yet discovered.
    4. ???
    Sep 2008
    Not hydrolocking, it had the same issue on the bench.
    The starter engages, piston comes to top dead center, then starter is unable to spin engine past tdc. If the battery is JUST coming off the charger it might spin normally the first time. After that same issue. Again, tried several batts, jump box, car battery, etc.
    Oct 2013
    Ohio
    Can you spin the motor past TDC by hand?
    Do you have an amp meter, you check the current draw when the started is trying to turn the motor over?
    What happens when you try to spin, with the plugs out?
    Sep 2008
    Yes
    No
    Spins normally
    Try spinning it with a fully charged battery. Meter attached to battery, and watch voltage drop. Let us know.
    Oct 2013
    Ohio
    If everything checks out mechanically, I believe you need to focus on electrical issues. You need a clamp on amp meter, something like this, https://www.amazon.com/Voltcraft-VC3...-1-spons&psc=1
    MAKE SURE, you get one that can measure DC, many you see online look the same, but cannot measure DC.
    Without it, you are driving blind trying to fix your problem.
    Good Luck
    ps... Maybe there is a gerbil stuck in it..
