Mikuni Carb clear diaphrams
    May 2013
    Vancouver
    Is there a proper side to install the round clear diaphrams? I hate to damage the rubber plugs should I have to pull out and reinstall. Thanks !
    Top Dog Boz Mon's Avatar
    Jun 2005
    Kankakee River
    Re: Mikuni Carb clear diaphrams
    There’s a special tool to do it. I usually use lots of lube and press with my thumb. I’ve heard of people using Allen keys with the ball end too
    1994 FX1
    1985 JS550/650 conversion
    2015 Fiat 500 Abarth
    PWCToday Regular SBT-Tech's Avatar
    Clearwater Florida
    Use some waxed dental floss.
    Wrap it around the grommet then pull the dental floss thru the hole.
    You will wonder why you struggled before.
    Post falls Idaho
    May 2013
    Vancouver
    There is a specific side the ring is installed? Will it run if mounted on wrong side?
    Top Dog JC-SuperJet's Avatar
    Cypress, TX
    The Check Valve Discs are cut from a plastic sheet that comes in rolls.
    Therefore, the Discs will have a slight curl.
    The "curl" side must face towards the plate so it can lay flat and seal properly.
    If you install the Disc the other way, they will leak because they won't lay flat and seal properly.
    Aug 2015
    Birmingham
    Quote Originally Posted by Boz Mon View Post
    hehe
