1997 GTS 720 backfiring
Page 1 of 3 123 LastLast
Results 1 to 10 of 23
    jacksonville, fl
    What is causing my 720 GTS engine to backfire, it will start and idle good up to 1/3 throttle, but starts to backfire at more then 1/3 throttle
    Re: 1997 GTS 720 backfiring
    When was the last time the carb was rebuilt/cleaned ?? When was the last time it ran right ??
    jacksonville, fl
    I rebuilt the 1st carb two times, and that did not fix it, so i put another carb on it, same problem
    jacksonville, fl
    It was a used engine and i don't have history on when it last ran, comp at 150psi, starts good idles good.
    Sep 2008
    The flakka capitol of Florida
    New plugs, check rectifier, check fuel selector for clogs, replace fuel line, inspect pulse lines
    jacksonville, fl
    Do you think it is going lean? i have installed new fuel lines, filter,pulse line, and installed a good fuel selector, Why rectifier?
    Sounds like a carb issue,what kind of kit did you use ?? Does it have a accel pump ??
    May 2009
    the 'ville, kentucky
    does a 97 GTS have an accel pump?
    jacksonville, fl
    no accel pump. on 97 GTS one carb, Monday i will try to use the choke to check if it is running lean. if that helps i will order a carb kit and rebuilt the 2 nd carb
    Jun 2011
    Be sure the plugs that are installed are NGK BR8ES & gapped to 0.20”-0.24”
    RAVE Valve possibly has incorrect timing? Should have a 147* valve.
    What would Chuck Norris do?
