sxr 1500 water box removal
Results 1 to 10 of 11
    PWCToday Guru futom's Avatar
    May 2007
    medina, Ohio
    Started removing my waterbox last night from my 1500. Having it welded. It looks like the entire engine needs to come out. Was hoping to just slide engine forward but no luck. If you have done this, what worked?
    dogs are my favorite people
    May 2007
    medina, Ohio
    Re: sxr 1500 water box removal
    Bump. Any input here would be appreciated. Anyone??
    May 2007
    medina, Ohio
    If your looking to do this loosen the engine bolts, remove exhaust manifold. Cut that waterborne open. +3mph
    May 2005
    Kansas City
    Got pics of it opened up? Or did you basically cut it and half and get the insides out?
    Jeremy S.
    May 2007
    medina, Ohio
    I'm not sure why my post says +3 mph. I don't recall posting that. It added mid range. Bad *** growl. Nothing up top. I used a black sharpie to diagram the flow on the outside of the waterbox. You need to be really accurate. It has specific tube lengths, chambers and flow route. If you just cut it might end in disaster. I removed some of the extra baffles. Shortened it 3". Then had my friend weld it up. I have pics somewhere. You can see enough of the internals to diagram safely.
    Dec 2014
    United States
    Did you ever post the pics? Looking to do the same to my machine
    May 2007
    medina, Ohio
    Lack of interest, so I never posted pics. You will need a skilled guy to weld the box back together. Basically the engine needs to come out. Over hoist helps. Make sure you understand the flow before cutting. Use a sharpie and make everything on the outside of the box. You only need to remove the rear most set of baffles.
    PWCToday Regular nvdafreek's Avatar
    Jan 2008
    Las Vegas
    So if you remove the front baffles it screws up the flow? Handling? My buddy cut and removed the front baffles and now his ski rides like itís a pencil. Very unstable and wants to torque to the right when off throttle.
    May 2007
    medina, Ohio
    Im not sure what you are referring to? The baffles Im referring to are inside the water box. If you removed the sponsons its going to be a rough ride.
    Jan 2008
    Las Vegas
    Nevermind. He put in a stock water box and didnít fix the problem. My buddy has a 5mil cut back on his 13/17 impeller. Heís gonna shim it to stock and see if that fixes it. He has the jcracing sponsons on his as do I and they work great.
