650sx stator: 4 wire and 5 wire???
    May 2019
    NC
    I made the mistake of ordering a 4 wire stator when my previous was a 5 wire.
    The 5 wire has 2 yellow and 1 black wire coming from the charging coil. The black wire is connecting to the rectifier. I've read that this wire is only an "extra ground". Is this true?
    The 4 wire stator has only 2 brown wires coming from the charging coil and going to the rectifier. There is one black wire coming out of the charging coil and grounding to the stator body itself. Do I need to run that wire to the rectifier or can I just ground that rectifier connection?
    Idaho/California
    Re: 650sx stator: 4 wire and 5 wire???
    Purple to black / red
    Brown to yellow
    Brown to yellow
    Black / yellow to black/yellow
    Black , leave loose
    Run a ground cable sub box to engine for super ground
    Do not pinch orange power wire when box goes together
    Or I'll sell you another stator
    Check for shorts before hooking up battery
    Or I'll be selling you a stator
    May 2019
    NC
    Brown to yellow
    Brown to yellow
    Black , leave loose
    Exactly what I thought! Thanks! I'll buy a total loss system if you have it. ��
    Idaho/California
    Negative on TL
    May 2019
    NC
    Negative on TL
    So I've got everything installed and buttoned up. Went to start and it's acting like the ignition timing is too far advanced. I put stator timing mark on the mark on the case and it's acting like it's trying to fire btdc. Is this normal?
